cluster-switch
cluster-switch-configure-health-monitor
This ONTAPI call does not have an equivalent REST API call.
cluster-switch-create
cluster-switch-delete
cluster-switch-get-iter
GET /api/network/ethernet/switches
| ONTAPI attribute | REST attribute | Comment |
address |
address |
device |
name |
is-monitoring-enabled-operational |
monitoring.monitored |
model |
model |
node |
No REST Equivalent |
reason |
monitoring.reason |
serial-number |
serial_number |
sw-version |
version |
type |
network |
version-source |
max-records |
max_records |
The maximum number of records to return before paging |
cluster-switch-modify
PATCH /api/network/ethernet/switches
address |
address |
community-or-username |
snmp.user |
device |
is-monitoring-enabled-admin |
monitoring.enabled |
model |
snmp-version |
snmp.version |
type |
cluster-switch-poll-get
cluster-switch-poll-modify
