ONTAP Select
ONTAP Select support for ONTAP features
Contributors netapp-revathid netapp-pcarriga
ONTAP Select offers full support for most ONTAP functionality. Many of the ONTAP features are licensed automatically for each node when you deploy a cluster. However some features require a separate license.
Note ONTAP features that have hardware-specific dependencies are generally not supported with ONTAP Select.
ONTAP features automatically enabled by default
The following ONTAP features are supported with ONTAP Select and licensed by default:
  • Autonomous Ransomware Protection (ARP) (manual updates)
  • CIFS
  • Deduplication and compression
  • FlexCache
    There are limitations to the support for FlexCache write-back with ONTAP Select. For more information, refer to FlexCache write-back with ONTAP Select.
  • FlexClone
  • iSCSI
  • NDMP
  • NetApp Volume Encryption (non-restricted countries only)
  • NFS
  • NVMe over TCP
  • ONTAP multitenancy capability
  • ONTAP S3
  • SnapMirror
  • S3 SnapMirror
  • SnapRestore
  • SnapVault
  • Storage VM disaster recovery (SVM DR)
    Note ONTAP Select supports SVM DR as both a source and destination with a maximum of 16 relationships. SVM DR support is limited to the use of the source ONTAP version to versions +2. For example, the ONTAP Select 9.12.1 source can connect to destination ONTAP versions 9.12.1, 9.13.1, or 9.14.1.
ONTAP features that are separately licensed
You must acquire a separate license for any ONTAP feature that is not enabled by default, including:
  • FabricPool
  • MetroCluster SDS (ONTAP Select premium license offering)
  • SnapLock Enterprise (SnapLock Compliance is not supported for ONTAP Select)
    • Tamperproof Snapshot copies
Note You do not need a FabricPool license when utilizing StorageGRID.
