ONTAP Select support for ONTAP features
ONTAP Select supports most ONTAP features. Many of the ONTAP features are licensed automatically for each node when you deploy a cluster. However some features require a separate license.
ONTAP features that have hardware-specific dependencies are generally not supported with ONTAP Select. |
ONTAP features automatically enabled by default
The following ONTAP features are supported with ONTAP Select and licensed by default:
Autonomous Ransomware Protection (ARP) (manual updates)
CIFS
Deduplication and compression
FlexCache
There are limitations to the support for FlexCache write-back with ONTAP Select. For more information, refer to FlexCache write-back with ONTAP Select.
FlexClone
iSCSI
NDMP
NetApp Volume Encryption (non-restricted countries only)
NFS
NVMe over TCP
ONTAP multitenancy capability
ONTAP S3
S3 SnapMirror
SnapLock Select
SnapLock Select is the implementation of ONTAP SnapLock designed for ONTAP Select and includes SnapLock Enterprise. It does not include SnapLock Compliance.
Learn about ONTAP SnapLock
SnapMirror
ONTAP Select does not support consistency groups in Asynchronous SnapMirror.
SnapRestore
SnapVault
Storage VM disaster recovery (SVM DR)
ONTAP Select supports SVM DR as both a source and destination with a maximum of 16 relationships. SVM DR support is limited to the use of the source ONTAP version to versions +2. For example, the ONTAP Select 9.12.1 source can connect to destination ONTAP versions 9.12.1, 9.13.1, or 9.14.1.
ONTAP features that are separately licensed
You need to acquire a separate license for any ONTAP feature that is not enabled by default, including:
FabricPool
MetroCluster SDS (ONTAP Select premium license offering)
SnapMirror cloud
You need to open a non-technical support case to obtain a SnapMirror cloud license.
Learn about SnapMirror cloud backups to object storage
