ONTAP Select
ONTAP Select support for ONTAP features
Contributors netapp-revathid
ONTAP Select supports most ONTAP features. Many of the ONTAP features are licensed automatically for each node when you deploy a cluster. However some features require a separate license.
Note ONTAP features that have hardware-specific dependencies are generally not supported with ONTAP Select.
ONTAP features licensed by default
The following ONTAP features are supported with ONTAP Select and licensed by default:
  • Autonomous Ransomware Protection (ARP) (manual updates)
  • CIFS
  • Deduplication and compression
  • External key management using the Key Management Interoperability Protocol (KMIP)
  • FlexCache
    ONTAP Select supports FlexCache cache volumes with write-back. FlexCache origin volumes with write-back are not supported.
  • FlexClone
  • iSCSI
  • NDMP
  • NetApp Volume Encryption (non-restricted countries only)
  • NFS
  • NVMe over TCP
  • ONTAP multitenancy capability
  • ONTAP S3
  • S3 SnapMirror
  • SnapLock Select
    SnapLock Select is the implementation of ONTAP SnapLock designed for ONTAP Select and includes SnapLock Enterprise. It does not include SnapLock Compliance.
    Learn about ONTAP SnapLock
  • SnapMirror
    ONTAP Select does not support consistency groups in Asynchronous SnapMirror.
  • SnapRestore
  • SnapVault
  • Storage VM disaster recovery (SVM DR)
    ONTAP Select supports SVM DR as both a source and destination with a maximum of 16 relationships. SVM DR support is limited to the use of the source ONTAP version to versions +2. For example, the ONTAP Select 9.16.1 source can connect to destination ONTAP versions 9.16.1, 9.17.1, or 9.18.1.
ONTAP features that are separately licensed
You need to acquire a separate license for any ONTAP feature that is not licensed by default, including:
