ONTAP Select
Initial state of the ONTAP Select cluster after deployment
Contributors netapp-revathid
You should be aware of the initial state of a cluster after it has been deployed and configure the cluster as needed for your environment.
An ONTAP Select cluster has several characteristics after it is created.
Note Restricting roles and permissions for the ONTAP administrator account can limit ONTAP Select Deploy's ability to manage the cluster. For more information, refer to the Knowledge Base article OTS Deploy cluster refresh fails with error.
LIFs
There are two types of customer-specified LIFs assigned:
  • Cluster management (one per cluster)
  • Node management (one per node)
Note A multi-node cluster has an internal network with autogenerated LIFs.
SVMs
Three SVMs are active:
  • Admin SVM
  • Node SVM
  • System (cluster) SVM
Note Data SVMs aren't created as part of the ONTAP Select cluster deployment. They must be created by the cluster administrator after deployment. For more information, see Create an SVM.
Aggregates
The root aggregate is created.
Features
All features are licensed and available. Both SnapLock and FabricPool require separate licenses.
