Expand or shrink Storage of vVol Datastore
There are APIs to increase or decrease the available storage.
Steps
Use the following API to expand or shrink the vVols datastore:
PATCH
/virtualization/api/v1/vcenters/{vcguid}/vvols/datastores/{moref}/volumes
Modify vVols datastore for add new volume
PATCH virtualization/api/v1/vcenters/cdded9ad-6bsd-4c9e-b44g-691250bfe2df/vvols/datastores/datastore-24/volumes
Request Body
"operation": "grow",
"volumes": [{
"is_existing": false,
"name": "exp3",
"size_in_mb": 51200,
"space_efficiency": "thin",
"aggregate": {
"id": "1466e4bf-c6d6-411a-91d5-c4f56210e1ab"
"storage_backend": {
"storage_id": "13d86e4f-1fb1-11ee-9509-005056a75778"
"qos": {
"max_iops": 5000
Modify vVols datastore for add existing volume
Request Body
"volumes": [{
"is_existing": true,
"id": "vfded9ad-6bsd-4c9e-b44g-691250bfe2sd"
Modify vVols datastore for remove volume and delete volume from storage
PATCH virtualization/api/v1/vcenters/cdded9ad-6bsd-4c9e-b44g-691250bfe2df/vvols/datastores/datastore-24/volumes?delete_volumes=true
Request Body
"operation": "shrink",
"volumes": [{
Modify vVols datastore for remove volume and do not delete volume from storage
PATCH virtualization/api/v1/vcenters/cdded9ad-6bsd-4c9e-b44g-691250bfe2df/vvols/datastores/datastore-24/volumes?delete_volumes=false
Request Body
"volumes": [{
