Expand or shrink Storage of vVol Datastore
There are APIs to increase or decrease the available storage.
Steps
Use the following API to expand or shrink the vVols datastore:
PATCH /virtualization/api/v1/vcenters/{vcguid}/vvols/datastores/{moref}/volumes
Modify vVols datastore for add new volume
PATCH virtualization/api/v1/vcenters/cdded9ad-6bsd-4c9e-b44g-691250bfe2df/vvols/datastores/datastore-24/volumes Request Body { "operation": "grow", "volumes": [{ "is_existing": false, "name": "exp3", "size_in_mb": 51200, "space_efficiency": "thin", "aggregate": { "id": "1466e4bf-c6d6-411a-91d5-c4f56210e1ab" }, "storage_backend": { "storage_id": "13d86e4f-1fb1-11ee-9509-005056a75778" }, "qos": { "max_iops": 5000 } }] }
Modify vVols datastore for add existing volume
PATCH virtualization/api/v1/vcenters/cdded9ad-6bsd-4c9e-b44g-691250bfe2df/vvols/datastores/datastore-24/volumes Request Body { "operation": "grow", "volumes": [{ "is_existing": true, "id": "vfded9ad-6bsd-4c9e-b44g-691250bfe2sd" }] }
Modify vVols datastore for remove volume and delete volume from storage
PATCH virtualization/api/v1/vcenters/cdded9ad-6bsd-4c9e-b44g-691250bfe2df/vvols/datastores/datastore-24/volumes?delete_volumes=true Request Body { "operation": "shrink", "volumes": [{ "is_existing": true, "id": "vfded9ad-6bsd-4c9e-b44g-691250bfe2sd" }] }
Modify vVols datastore for remove volume and do not delete volume from storage
PATCH virtualization/api/v1/vcenters/cdded9ad-6bsd-4c9e-b44g-691250bfe2df/vvols/datastores/datastore-24/volumes?delete_volumes=false Request Body { "operation": "shrink", "volumes": [{ "is_existing": true, "id": "vfded9ad-6bsd-4c9e-b44g-691250bfe2sd" }] }
