ONTAP tools for VMware vSphere 10
ONTAP tools upgrade error codes
Contributors netapp-jani jani
You might encounter error codes during ONTAP tools for VMware vSphere upgrade operation. The error codes are five digits long, where the first two digits represent the script that encountered the issue, and the last three digits represent the specific workflow within that script.
All error logs are recorded in the ansible-perl-errors.log file to facilitate easy tracking and resolution of issues. This log file contains the error code and the failed Ansible task.
Note The error codes provided on this page are for reference only. Contact the support team if the error persists or if there's no resolution mentioned.
The following table lists the error codes and the corresponding file names.
Error code
Script name
00
firstboot-network-config.pl, mode deploy
01
firstboot-network-config.pl, mode upgrade
02
firstboot-inputs-validation.pl
03
firstboot-deploy-otv-ng.pl, deploy, HA
04
firstboot-deploy-otv-ng.pl, deploy, non-HA
05
firstboot-deploy-otv-ng.pl, reboot
06
firstboot-deploy-otv-ng.pl, upgrade, HA
07
firstboot-deploy-otv-ng.pl, upgrade, non-HA
08
firstboot-otv-recovery.pl
09
post-deploy-upgrade.pl
The last three digits of the error code indicate the specific workflow error within the script:
Upgrade error code Workflow Resolution
052
The ISO might be the same as the current version or two releases above the current version.
Use an ISO version compatible to upgrade from your current version.
068
Debian OS packages rollback has failed
Use zero-RPO or snapshot based recovery and retry upgrade.
069
Failed restoring files
070
Failed deleting backup
071
Kubernetes cluster was not healthy
074
Mount ISO has failed
Check the /var/log/otvng/upgrade-run.log and retry upgrade.
075
Upgrade pre-checks has failed
Retry the upgrade.
076
Registry upgrade has failed
077
Registry rollback has failed
078
Operator upgrade has failed
079
Operator rollback has failed
080
Services upgrade has failed
081
Services rollback has failed
082
Deleting old images from container failed
083
Deleting backup has failed
084
Changing JobManager back to Production failed
Perform the following steps to recover/complete the upgrade.
1. Enable Diagnostic Shell
2. Run the command: sudo perl /home/maint/scripts/post-deploy-upgrade.pl --postupgrade
3. Check the logs at /var/log/otvng/post-deploy-upgrade.log
087
Post upgrade steps failed.
2. Run sudo perl /home/maint/scripts/post-deploy-upgrade.pl --postupgrade command
088
Configuring log rotate for journald has failed
Check the VM network settings compatible with the host on which the VM is hosted. You can try to migrate the VM to another host and restart.
089
Changing ownership of summary log rotate config file has failed
Retry the upgrade.
094
NTP configuration failed and the system rolled back to NTPsec
If the upgrade fails due to a failure in the Chrony installation:
  1. Check whether Chrony is installed:
    systemctl status chrony
  2. If Chrony is installed and the issue is with the NTP servers you provided, check whether those servers are reachable:
    sudo chronyc -N sources -v
    sudo chronyc tracking
    If the servers are reachable, the issue is unrelated to server reachability. If a server is genuinely unreachable, remove it from ONTAP tools Manager and provide a reachable NTP server instead.
  3. If the upgrade fails due to any other issue during the NTP upgrade, check the following logs:
    /var/log/otvng/ansible-perl-errors.log
    /var/log/otvng/ntp_configure.log
    /var/log/ansible-perl-errors.log
095
OS upgrade failed
No recovery for OS upgrade. ONTAP tools services are upgraded and new pods will be running.
096
Install dynamic storage provisioner
Check the upgrade logs and retry upgrade.
097
Uninstalling services for upgrade has failed
Use zero RPO or snapshot based recovery and retry upgrade.
098
copying dockercred secret from ntv-system to rook-ceph namespace has failed
099
Failed to validate the new HDD addition
Add the new HDD to all the nodes in case of HA and to one node in case of non-HA deployment.
108
Seeding script failed
109
backing up persistent volume data has failed
110
restoring persistent volume data has failed
111
Updating etcd timeout parameters for RKE2 has failed
112
Uninstall dynamic storage provisioner has failed
113
Refresh resources on secondary nodes has failed
104
Restarting of secondary node has failed
Restart the nodes manually, one by one.
100
kernel rollback has failed
051
dynamic storage provisioner upgrade has failed
Check upgrade logs and retry upgrade.
056
deleting migration backup has failed
NA
090
certificate validation for storage backends and vCenter failed
Check upgrade logs and log file at /var/log/otvng/cert_validation_error.log and retry the upgrade.
114
Internal certificate update in the MongoDB collection failed
If upgrade fails with error code 114, perform the following steps:
  1. Connect to the upgrade ISO on the primary node and enable the diagnostic shell.
  2. Mount the ISO from the SSH session to the primary node:
    sudo mount /dev/cdrom
    sudo mount -o loop,ro /dev/cdrom/APPLIANCE_UPGRADE.bin /upgrade
  3. Install Debian packages:
    sudo dpkg -iE /upgrade/dists/squeeze/main/binary-amd64/vplatform.deb
    sudo dpkg -iE /upgrade/dists/squeeze/main/binary-amd64/vpupgrader.deb
    sudo dpkg -iE /upgrade/dists/squeeze/main/binary-amd64/vmware-tools.deb
  4. Copy the build information file:
    sudo cp /upgrade/APPLIANCE_BUILD /
  5. Add certificates to the collection by enabling the diagnostic shell and running:
    sudo perl /home/maint/scripts/post-deploy-upgrade.pl --internal_cert_update_collection
    Check the logs at /var/log/otvng/post-deploy-upgrade.log.
  6. Reboot the nodes:
    sudo bash /home/maint/scripts/vault_decrypt.sh
    cd /home/maint/rke2-pb
    sudo ansible-playbook site.yaml --tags restart_nodes --skip-tags debian_upgrade,kernel_upgrade,rescan_scsi_bus,source_iso,eject_upgrade,mountIso,upgradeNodes,registryUpg,deleteOldImages,wait,checkReachability,delete_otv_cr,uninstall_trident,del_trident_images,refresh_resources,ntp_configure,ntpd_uninstall
  7. Perform post-upgrade steps:
  8. Verify successful completion by checking the logs:
    tail -f /var/log/otvng/post-deploy-upgrade.log
    Look for the success message: Completed post 10.5 upgrade steps.
  9. Eject the ISO:
    sudo umount -l -f /upgrade
    sudo umount -l -f /dev/cdrom
    sudo eject /dev/cdrom
  10. Reboot the primary node:
    sudo reboot -f
Note Beginning with ONTAP tools for VMware vSphere 10.3 zero RPO is not supported.
