Upgrade error codes
You might encounter error codes during ONTAP tools for VMware vSphere upgrade operation. The error codes are five digits long, where the first two digits represent the script that encountered the issue, and the last three digits represent the specific workflow within that script.
All error logs are recorded in the ansible-perl-errors.log file to facilitate easy tracking and resolution of issues. This log file contains the error code and the failed Ansible task.
The error codes provided on this page are for reference only. Contact the support team if error persists or if there's no resolution mentioned. |
The following table lists the error codes and the corresponding file names.
Error code |
Script name |
00 |
firstboot-network-config.pl, mode deploy |
01 |
firstboot-network-config.pl, mode upgrade |
02 |
firstboot-inputs-validation.pl |
03 |
firstboot-deploy-otv-ng.pl, deploy, ha |
04 |
firstboot-deploy-otv-ng.pl, deploy, non-ha |
05 |
firstboot-deploy-otv-ng.pl, reboot |
06 |
firstboot-deploy-otv-ng.pl, upgrade, ha |
07 |
firstboot-deploy-otv-ng.pl, upgrade, non-ha |
08 |
firstboot-otv-recovery.pl |
The last three digits of the error code indicate the specific workflow error within the script:
Upgrade error code |
Workflow |
Resolution |
063 |
Copying contents to recovery volume has failed |
Perform snapshot-based recovery. |
068 |
Debian packages rollback has failed |
069 |
Failed restoring files |
070 |
Failed deleting backup |
071 |
Kubernetes cluster was not healthy |
072 |
CR file does not exist in jail disk |
073 |
Applying the CR failed while setting force reconcile flag to false |
074 |
Mount ISO has failed |
Retry the upgrade. |
075 |
Upgrade pre-checks has failed |
076 |
Registry upgrade has failed |
077 |
Registry rollback has failed |
078 |
Operator upgrade has failed |
079 |
Operator rollback has failed |
080 |
Services upgrade has failed |
081 |
Services rollback has failed |
082 |
Deleting old images from container failed |
083 |
Deleting backup has failed |
084 |
Changing JobManager back to Production failed |
085 |
failed creating CA certificate secrets |
086 |
failed creating server/private-key certificate secrets |
087 |
Failed! to complete post 10.0 to 10.1 upgrade steps |
Post upgrade steps failed. |
088 |
Configuring log rotate for journald has failed |
089 |
Changing ownership of summary log rotate config file has failed |
091 |
iSCSI upgrade has failed |
092 |
iSCSI rollback has failed |
093 |
trident upgrade has failed |
094 |
trident rollback has failed |
095 |
Debian Upgrade failed |
No recovery for debian upgrade. Services are upgraded and new pods will be running |
