ONTAP tools for VMware vSphere 10
Upgrade error codes
Contributors netapp-revathid
You might encounter error codes during ONTAP tools for VMware vSphere upgrade operation. The error codes are five digits long, where the first two digits represent the script that encountered the issue, and the last three digits represent the specific workflow within that script.
All error logs are recorded in the ansible-perl-errors.log file to facilitate easy tracking and resolution of issues. This log file contains the error code and the failed Ansible task.
Note The error codes provided on this page are for reference only. Contact the support team if error persists or if there's no resolution mentioned.
The following table lists the error codes and the corresponding file names.
Error code
Script name
00
firstboot-network-config.pl, mode deploy
01
firstboot-network-config.pl, mode upgrade
02
firstboot-inputs-validation.pl
03
firstboot-deploy-otv-ng.pl, deploy, HA
04
firstboot-deploy-otv-ng.pl, deploy, non-HA
05
firstboot-deploy-otv-ng.pl, reboot
06
firstboot-deploy-otv-ng.pl, upgrade, HA
07
firstboot-deploy-otv-ng.pl, upgrade, non-HA
08
firstboot-otv-recovery.pl
09
post-deploy-upgrade.pl
The last three digits of the error code indicate the specific workflow error within the script:
Upgrade error code
Workflow
Resolution
068
Debian packages rollback has failed
Use zero-RPO or snapshot based recovery and retry upgrade.
069
Failed restoring files
070
Failed deleting backup
071
Kubernetes cluster was not healthy
074
Mount ISO has failed
Check the /var/log/upgrade-run.log and retry upgrade.
075
Upgrade pre-checks has failed
Retry the upgrade.
076
Registry upgrade has failed
077
Registry rollback has failed
078
Operator upgrade has failed
079
Operator rollback has failed
080
Services upgrade has failed
081
Services rollback has failed
082
Deleting old images from container failed
083
Deleting backup has failed
084
Changing JobManager back to Production failed
Follow the below steps to recover/complete the upgrade.
1. Enable Diagnostic Shell
2. Run the command: sudo perl /home/maint/scripts/post-deploy-upgrade.pl --postupgrade
3. Check the logs at /var/log/post-deploy-upgrade.log
087
Post upgrade steps failed.
Perform the following steps to recover/complete the upgrade.
2. Run sudo perl /home/maint/scripts/post-deploy-upgrade.pl --postupgrade command
088
Configuring log rotate for journald has failed
Check the VM network settings compatible with the host on which VM is hosted. You can try to migrate the VM to another host and restart.
089
Changing ownership of summary log rotate config file has failed
Retry the upgrade.
093
Dynamic storage provisioner upgrade has failed
Retry the upgrade.
094
Dynamic storage provisioner rollback has failed
Retry the upgrade.
095
OS upgrade failed
No recovery for OS upgrade. ONTAP tools services are upgraded and new pods will be running.
096
Install dynamic storage provisioner
Check the upgrade logs and retry upgrade.
097
Uninstalling services for upgrade has failed
Use zero RPO or snapshot based recovery and retry upgrade.
098
copying dockercred secret from ntv-system to dynamic storage provisioner namespace has failed
099
Failed to validate the new HDD addition
Add the new HDD to all the nodes in case of HA and to one node in case of non-HA deployment.
108
Seeding script failed
109
backing up persistent volume data has failed
110
restoring persistent volume data has failed
111
Updating etcd timeout parameters for RKE2 has failed
112
Uninstall dynamic storage provisioner has failed
113
Refresh resources on secondary nodes has failed
Note ONTAP tools for VMware vSphere 10.3 does on support zero RPO.
