Upgrade error codes
You might encounter error codes during ONTAP tools for VMware vSphere upgrade operation. The error codes are five digits long, where the first two digits represent the script that encountered the issue, and the last three digits represent the specific workflow within that script.
All error logs are recorded in the ansible-perl-errors.log file to facilitate easy tracking and resolution of issues. This log file contains the error code and the failed Ansible task.
The error codes provided on this page are for reference only. Contact the support team if error persists or if there's no resolution mentioned. |
The following table lists the error codes and the corresponding file names.
Error code |
Script name |
00 |
firstboot-network-config.pl, mode deploy |
01 |
firstboot-network-config.pl, mode upgrade |
02 |
firstboot-inputs-validation.pl |
03 |
firstboot-deploy-otv-ng.pl, deploy, HA |
04 |
firstboot-deploy-otv-ng.pl, deploy, non-HA |
05 |
firstboot-deploy-otv-ng.pl, reboot |
06 |
firstboot-deploy-otv-ng.pl, upgrade, HA |
07 |
firstboot-deploy-otv-ng.pl, upgrade, non-HA |
08 |
firstboot-otv-recovery.pl |
09 |
post-deploy-upgrade.pl |
The last three digits of the error code indicate the specific workflow error within the script:
| Upgrade error code | Workflow | Resolution |
052 |
The ISO might be the same as the current version or two releases above the current version. |
Use an ISO version compatible to upgrade from your current version. |
068 |
Debian packages rollback has failed |
Use zero-RPO or snapshot based recovery and retry upgrade. |
069 |
Failed restoring files |
070 |
Failed deleting backup |
071 |
Kubernetes cluster was not healthy |
074 |
Mount ISO has failed |
Check the /var/log/upgrade-run.log and retry upgrade. |
075 |
Upgrade pre-checks has failed |
Retry the upgrade. |
076 |
Registry upgrade has failed |
077 |
Registry rollback has failed |
078 |
Operator upgrade has failed |
079 |
Operator rollback has failed |
080 |
Services upgrade has failed |
081 |
Services rollback has failed |
082 |
Deleting old images from container failed |
083 |
Deleting backup has failed |
084 |
Changing JobManager back to Production failed |
Follow the below steps to recover/complete the upgrade. 1. Enable Diagnostic Shell 2. Run the command: sudo perl /home/maint/scripts/post-deploy-upgrade.pl --postupgrade 3. Check the logs at /var/log/post-deploy-upgrade.log |
087 |
Post upgrade steps failed. |
Perform the following steps to recover/complete the upgrade. 1. Enable Diagnostic Shell 2. Run sudo perl /home/maint/scripts/post-deploy-upgrade.pl --postupgrade command 3. Check the logs at /var/log/post-deploy-upgrade.log |
088 |
Configuring log rotate for journald has failed |
Check the VM network settings compatible with the host on which VM is hosted. You can try to migrate the VM to another host and restart. |
089 |
Changing ownership of summary log rotate config file has failed |
095 |
OS upgrade failed |
No recovery for OS upgrade. ONTAP tools services are upgraded and new pods will be running. |
096 |
Install dynamic storage provisioner |
Check the upgrade logs and retry upgrade. |
097 |
Uninstalling services for upgrade has failed |
Use zero RPO or snapshot based recovery and retry upgrade. |
098 |
copying dockercred secret from ntv-system to dynamic storage provisioner namespace has failed |
099 |
Failed to validate the new HDD addition |
Add the new HDD to all the nodes in case of HA and to one node in case of non-HA deployment. |
108 |
Seeding script failed |
109 |
backing up persistent volume data has failed |
110 |
restoring persistent volume data has failed |
111 |
Updating etcd timeout parameters for RKE2 has failed |
112 |
Uninstall dynamic storage provisioner has failed |
113 |
Refresh resources on secondary nodes has failed |
104 |
Restarting of secondary node has failed |
Restart the nodes manually one by one |
100 |
kernel rollback has failed |
051 |
dynamic storage provisioner upgrade has failed |
Check upgrade logs and retry upgrade. |
056 |
deleting migration backup has failed |
NA |
Beginning with ONTAP tools for VMware vSphere 10.3 zero RPO is not supported. |
