ONTAP tools for VMware vSphere 10.1
Delete vVols datastore
A vVols datastore exists as long as at least one FlexVol volume is available on the datastore. If you want to delete a vVols datastore in a HA cluster, you should first unmount the datastore from all hosts within the HA cluster, and then delete the residing .vsphere-HA folder manually using the vCenter server user interface.
Steps
Use the following API to delete vVols datastore.
DELETE
​/virtualization​/api​/v1​/vcenters​/{vcguid}​/vvols​/datastores​/{moref}
  • Delete vVols datastore and delete volumes from storage
  DELETE /api/v1/vcenters/cdded9ad-6bsd-4c9e-b44g-691250bfe2df/vvols/datastores/datastore-28?delete_volumes=true
Note Delete vVols Datastore workflow deletes datastore-volumes if you have passed the delete_volume flag as true irrespective of if the datastore-volume is managed or not managed.
  • Delete vVols datastore and do not delete volumes from storage
  DELETE /api/v1/vcenters/cdded9ad-6bsd-4c9e-b44g-691250bfe2df/vvols/datastores/datastore-28?delete_volumes=false
Response:
    "id": "1889"
