ONTAP tools for VMware vSphere 9.10
How to configure ONTAP role-based access control for ONTAP tools for VMware vSphere
Contributors jani netapp-manishc
You must configure ONTAP role-based access control (RBAC) on the storage system if you want to use role-based access control with ONTAP tools for VMware vSphere. You can create one or more custom user accounts with limited access privileges with the ONTAP RBAC feature.
VSC and SRA can access storage systems at either the cluster level or the storage virtual machine (SVM)SVM level. If you are adding storage systems at the cluster level, then you must provide the credentials of the admin user to provide all of the required capabilities. If you are adding storage systems by directly adding SVM details, you must be aware that the “vsadmin” user does not have all of the required roles and capabilities to perform certain tasks.
VASA Provider can access storage systems only at the cluster level. If VASA Provider is required for a particular storage controller, then the storage system must be added to VSC at the cluster level even if you are using VSC or SRA.
To create a new user and to connect a cluster or an SVM to ONTAP tools, you should perform the following:
  • Create a cluster administrator or an SVM administrator role
    Note You can use one of the following to create these roles:
  • Create users with the role assigned and the appropriate application set using ONTAP
    You require these storage system credentials to configure the storage systems for VSC. You can configure storage systems for VSC by entering the credentials in VSC. Each time you log in to a storage system with these credentials, you will have permissions to the VSC functions that you had set up in ONTAP while creating the credentials.
  • Add the storage system to VSC and provide the credentials of the user that you just created
VSC roles
VSC classifies the ONTAP privileges into the following set of VSC roles:
  • Discovery
    Enables the discovery of all of the connected storage controllers
  • Create Storage
    Enables the creation of volumes and logical unit number (LUNs)
  • Modify Storage
    Enables the resizing and deduplication of storage systems
  • Destroy Storage
    Enables the destruction of volumes and LUNs
VASA Provider roles
You can create only Policy Based Management at the cluster level. This role enables policy-based management of storage using storage capabilities profiles.
SRA roles
SRA classifies the ONTAP privileges into a SAN or NAS role at either the cluster level or the SVM level. This enables users to run SRM operations.
VSC performs an initial privilege validation of ONTAP RBAC roles when you add the cluster to VSC. If you have added a direct SVM storage IP, then VSC does not perform the initial validation. VSC checks and enforces the privileges later in the task workflow.
