Set-SmMultiFactorAuthentication
To Enable or disable the MFA feature or to configure the MFA for the SnapCenter GUI, Rest API, PowerShell and sccli.
Syntax
Set-SmMultiFactorAuthentication [-IsGuiMFAEnabled] <> [-IsRestApiMFAEnabled ] <> [-IsCliMFAEnabled ] <> [-Path] <> [-Path] <> [-IsGuiMFAEnabled] <> [-IsRestApiMFAEnabled ] <> [-IsCliMFAEnabled ] <>
Detailed Description
To enable or disable the MFA feature or to configure the MFA for the SnapCenter GUI, Rest API, PowerShell and sccli.
| Name | Description | Required? | Pipeline Input | Default Value |
IsGuiMFAEnabled |
Specifies the SnapCenter Server to enable or disable MFA for the SnapCenter GUI. |
false |
false |
IsRestApiMFAEnabled |
Specifies the SnapCenter Server to enable or disable MFA for the SnapCenter Rest API. |
false |
false |
IsCliMFAEnabled |
Specifies the SnapCenter Server to enable or disable MFA for the SnapCenter PowerShell and sccli. |
false |
false |
Path |
Configure the MFA for the SnapCenter Server login with specified AD FS metadata file path. |
false |
false |
Example 1: Enabling MultiFactorAuthentication for GUI, Rest API, PowerShell and sccli
Set-SmMultiFactorAuthentication -IsGuiMFAEnabled $true -IsRestApiMFAEnabled $true -IsCliMFAEnabled $true -Path C:\ADFS_metadata\FederationMetadata.xml
This example syntax enables MFA for SnapCenter GUI, Rest API, PowerShell and sccli configured with specified AD FS metadata file path.
IsGuiMFAEnabled = True
ADFSConfigFilePath = C:\\ADFS_metadata\\FederationMetadata.xml
SCConfigFilePath = c:\ProgramData\NetApp\SnapCenter\Package Repository\SnapCenterMFAMetadata.xml
IsRestApiMFAEnabled = True
IsCliMFAEnabled = True
ADFSHostName = adfs19.ad19domain.com
Example 2: Disabling MultiFactorAuthentication for SnapCenter GUI
Set-SmMultiFactorAuthentication -IsGuiMFAEnabled $false
This example syntax disables MFA for SnapCenter GUI.
IsGuiMFAEnabled = False
ADFSConfigFilePath = null
SCConfigFilePath = null
IsRestApiMFAEnabled = False
IsCliMFAEnabled = False
ADFSHostName = null
Example 3: Enabling MultiFactorAuthentication for Rest API PowerShell and sccli
Set-SmMultiFactorAuthentication -IsRestApiMFAEnabled $true -IsCliMFAEnabled $true -Path C:\ADFS_metadata\FederationMetadata.xml
This example syntax enables MFA for SnapCenter Rest API, PowerShell and sccli configured with specified AD FS metadata file path.
Example 4: Enabling MultiFactorAuthentication only for PowerShell and sccli
Set-SmMultiFactorAuthentication -IsCliMFAEnabled $true -Path C:\ADFS_metadata\FederationMetadata.xml
This example syntax enables MFA for SnapCenter PowerShell and sccli configured with specified AD FS metadata file path.
Example 5: Disabling MultiFactorAuthentication for GUI, Rest API, PowerShell and sccli
Set-SmMultiFactorAuthentication -IsGuiMFAEnabled $False -IsRestApiMFAEnabled $False -IsCliMFAEnabled $False
This example syntax disables MFA for SnapCenter GUI, Rest API, PowerShell and sccli.
ADFSHostName = null
Example 6: Disabling MultiFactorAuthentication for Only for Rest API
Set-SmMultiFactorAuthentication -IsRestApiMFAEnabled $False
This example syntax disables MFA only for SnapCenter Rest API.
Example 7: Update MultiFactorAuthentication configuration
Set-SmMultiFactorAuthentication -Path C:\data\FederationMetadata.xml
This example syntax updates MFA configuration for SnapCenter configured with specified AD FS metadata file path.
ADFSConfigFilePath = C:\\data\\FederationMetadata.xml
