Manage StorageGRID tenant groups
Manage your tenant groups as needed to view, edit, or duplicate a group, and more.
Before you begin
View or edit group
You can view and edit the basic information and details for each group.
Steps
  1. Select Access Management > Groups.
  2. Review the information provided on the Groups page, which lists basic information for all local and federated groups for this tenant account.
    If the tenant account has the Use grid federation connection permission and you are viewing groups on the tenant's source grid:
    • A banner message indicates that if you edit or remove a group, your changes will not be synced to the other grid.
    • As needed, a banner message indicates if groups were not cloned to the tenant on the destination grid. You can retry a group clone that failed.
  3. If you want to change the group's name:
    1. Select the checkbox for the group.
    2. Select Actions > Edit group name.
    3. Enter the new name.
    4. Select Save changes.
  4. If you want to view more details or make additional edits, do either of the following:
    • Select the group name.
    • Select the checkbox for the group, and select Actions > View group details.
  5. Review the Overview section, which shows the following information for each group:
    • Display name
    • Unique name
    • Type
    • Access mode
    • Permissions
    • S3 Policy
    • Number of users in this group
    • Additional fields if the tenant account has the Use grid federation connection permission and you are viewing the group on the tenant's source grid:
      • Cloning status, either Success or Failure
      • A blue banner indicating that if you edit or delete this group, your changes will not be synced to the other grid.
  6. Edit group settings as needed. Refer to Create groups for an S3 tenant for details about what to enter.
    1. In the Overview section, change the display name by selecting the name or the edit icon Edit icon.
    2. On the Group permissions tab, update the permissions, and select Save changes.
    3. On the Group policy tab, make any changes, and select Save changes.
      Optionally select a different S3 group policy or enter the JSON string for a custom policy as required.
  7. To add one or more existing local users to the group:
    1. Select the Users tab.
      Manage users
    2. Select Add users.
    3. Select the existing users you want to add, and select Add users.
      A success message appears in the upper right.
  8. To remove local users from the group:
    2. Select Remove users.
    3. Select the users you want to remove, and select Remove users.
  9. Confirm that you selected Save changes for each section you changed.
Duplicate group
You can duplicate an existing group to create new groups more quickly.
Note If your tenant account has the Use grid federation connection permission and you duplicate a group from the tenant's source grid, the duplicated group will be cloned to the tenant's destination grid.
Steps
  2. Select the checkbox for the group you want to duplicate.
  3. Select Actions > Duplicate group.
  4. See Create groups for an S3 tenant for details about what to enter.
  5. Select Create group.
Retry group clone
To retry a clone that failed:
  1. Select each group that indicates (Cloning failed) below the group name.
  2. Select Actions > Clone groups.
  3. View the status of the clone operation from the details page of each group you're cloning.
For additional information, see Clone tenant groups and users.
Delete one or more groups
You can delete one or more groups. Any users who belong only to a group that is deleted will no longer be able to sign in to the Tenant Manager or use the tenant account.
Note If your tenant account has the Use grid federation connection permission and you delete a group, StorageGRID will not delete the corresponding group on the other grid. If you need to keep this information in sync, you must delete the same group from both grids.
Steps
  2. Select the checkbox for each group you want to delete.
  3. Select Actions > Delete group or Actions > Delete groups.
    A confirmation dialog box appears.
  4. Select Delete group or Delete groups.
Set up AssumeRole
Before you begin
You must be an administrator to set up AssumeRole.
About this task
To set up AssumeRole, create the target group to be assumed, if the group doesn't already exist. Edit the group's S3 policy to specify the permitted actions of assuming this group. Edit the group's S3 trust policy to specify the trusted users allowed to assume the group with the AssumeRole API.
Temporary security credentials created from assuming this group are valid for a limited duration. The session is between 15 minutes and 12 hours, and the default session is 1 hour. When you remove the user from the group's S3 trust policy, the user can no longer assume this group.
Steps
  2. Click on the group name.
  3. Select the S3 trust policy tab.
  4. Add your S3 trust policy, including a list of users that can perform AssumeRole.
  5. Select Save changes.
  6. Select the S3 group policy tab.
  7. Edit the S3 policy to specify only the required S3 actions for the trusted users added in this group's S3 trust policy.
  8. Select Save changes.
Example of an AssumeRole S3 trust policy
    "Statement": [
            "Effect": "Allow",
            "Action": "sts:AssumeRole",
            "Principal": {
                "AWS": [
                    "urn:sgws:identity::1234567890:user/user1",
                    "arn:aws:iam::1234567890:user/user2"
After configuration is complete, users listed in the S3 trust policy can perform AssumeRole and receive credentials. The final permissions are determined by group policy, bucket policy, and session policy. For more information see Use access policies.
