View and edit tenant group details in StorageGRID
When you view the details for a group, you can change the group's display name, permissions, policies, and the users that belong to the group.
Before you begin
  • You are signed in to the Tenant Manager using a supported web browser.
  • You belong to a user group that has the Root access permission.
Steps
  1. Select Access Management > Groups.
  2. Select the name of the group whose details you want to view or edit.
    Alternatively, you can select Actions > View group details.
    The group details page appears. The following example shows the S3 group details page.
    View Group Details
  3. Make changes to the group settings as needed.
    Tip To ensure your changes are saved, select Save changes after you make changes in each section. When your changes are saved, a confirmation message appears in the upper right corner of the page.
    1. Optionally, select the display name or edit icon Edit icon to update the display name.
      You can't change a group's unique name. You can't edit the display name for a federated group.
    2. Optionally, update the permissions.
    3. For group policy, make the appropriate changes for your S3 tenant.
      • If you are editing a group for an S3 tenant, optionally select a different S3 group policy. If you select a custom S3 policy, update the JSON string as required.
    4. Optionally, add or remove users.
  4. Confirm that you have selected Save changes for each section you changed.
Related information
