Replace the CMOS battery in an SG110 or SG1100
Use this procedure to replace the CMOS coin cell battery on the system board.
Use these procedures to:
Remove the CMOS battery
Reinstall the CMOS battery
You have verified the SG110 or SG1100 where the CMOS battery needs to be replaced.
You have physically located the SG110 or SG1100 appliance where you are replacing the CMOS battery in the data center.
You have recorded the current BMC configuration of the appliance, if it remains available.
Log in to the appliance to be replaced:
Enter the following command:
ssh admin@grid_node_IP -
Enter the password listed in the
Passwords.txtfile. -
Enter the following command to switch to root:
su - -
Passwords.txtfile.When you are logged in as root, the prompt changes from
$to#.
Enter:
run-host-command ipmitool lan printto display the current BMC configuration for the appliance.A controlled shutdown of the appliance is required before removing the appliance from the rack.
You have disconnected all cables and removed the appliance cover.
To prevent service interruptions, confirm that all other Storage Nodes are connected to the grid before starting the CMOS battery replacement or replace the battery during a scheduled maintenance window when periods of service disruption are acceptable. See the information about monitoring node connection states.
Wrap the strap end of the ESD wristband around your wrist, and secure the clip end to a metal ground to prevent static discharge.
Locate the two-slot riser assembly at the rear of the appliance.
Grasp the riser assembly through the blue-marked holes and carefully lift it upwards. Move the riser assembly toward the front of the chassis as you lift it to allow the external connectors in its installed NICs to clear the chassis.
Place the riser on a flat anti-static surface with the metal frame side down.
Locate the CMOS battery on the system board in the position beneath the removed riser assembly.
Use your finger or a plastic pry tool to press the retaining clip (highlighted) away from the battery to spring it from the socket.
Remove the battery and dispose of it properly.
Install the replacement CMOS battery into the socket on the system board.
You have the correct replacement CMOS battery (CR2032).
You have removed the failed CMOS battery.
Remove the CMOS battery from its packaging.
Press the replacement battery into the empty socket on the system board with the positive (+) side up until the battery snaps in place.
Locate the alignment hole on the two-slot riser assembly (circled) that aligns with the guide pin on the system board to ensure correct riser assembly positioning.
Locate the guide pin on the system board
Position the riser assembly in the chassis, making sure that it aligns with the connector on the system board and guide pin.
Carefully press the two-slot riser assembly in place along its center line, next to the blue-marked holes, until it is fully seated.
If you have no other maintenance procedures to perform in the appliance, reinstall the appliance cover, return the appliance to the rack, attach cables, and apply power.
If the appliance you replaced had drive encryption enabled for the SED drives, you must enter the drive encryption passphrase to access the encrypted drives when the replacement appliance starts for the first time.
If the appliance you replaced used a key management server (KMS) to manage encryption keys for node encryption, additional configuration might be required before the node can join the grid. If the node does not automatically join the grid, make sure that these configuration settings have transferred to the new appliance and manually configure any settings that don't have the expected configuration:
Log in to the appliance:
su - -
Passwords.txtfile.
Restore BMC network connectivity for the appliance. There are two options:
Use static IP, netmask, and gateway
Use DHCP to obtain an IP, netmask, and gateway
To restore the BMC configuration to use a static IP, netmask, and gateway, enter the following commands:
run-host-command ipmitool lan set 1 ipsrc staticrun-host-command ipmitool lan set 1 ipaddr Appliance_IPrun-host-command ipmitool lan set 1 netmask Netmask_IPrun-host-command ipmitool lan set 1 defgw ipaddr Default_gateway -
To restore the BMC configuration to use DHCP to obtain an IP, netmask, and gateway, enter the following command:
run-host-command ipmitool lan set 1 ipsrc dhcp
After restoring BMC network connectivity, connect to the BMC interface to audit and restore any additional custom BMC configuration you might have applied. For example, you should confirm the settings for SNMP trap destinations and email notifications. See Configure BMC interface.
Confirm that the appliance node appears in the Grid Manager and that no alerts appear.
