StorageGRID appliances
BMC interface for SG6000, SG6100, and SG6200 StorageGRID appliances and services appliances
Contributors netapp-perveilerk netapp-pcarriga netapp-ivanad netapp-jsnyder
The user interface for the baseboard management controller (BMC) provides status information about your hardware and allows low-level hardware access for appliance configuration, monitoring, and diagnosis.
You can use the BMC to:
  • Troubleshoot your hardware installation
  • Configure SNMP settings
  • Determine your appliance's power state
  • Control the identify LED on your appliance
The following StorageGRID appliances support the BMC interface:
  • SG100
  • SG110
  • SG120
  • SG1000
  • SG1100
  • SG1200
  • SGF6024
  • SGF6112
  • SGF6212
  • SG6060
  • SG6160
  • SG6260
If you are installing your appliance, use the following procedures to configure the BMC:
If you have already installed the appliance into a grid and it's running StorageGRID software, use the following procedures:
To learn more about what features you can use with the BMC after you have configured it, refer to Use the BMC interface and the BMC User Guide.
