StorageGRID appliances
Automate StorageGRID appliance installation and configuration
Contributors netapp-perveilerk netapp-pcarriga netapp-lhalbert
Automating installation and configuration can be useful for deploying multiple StorageGRID instances or one large, complex StorageGRID instance.
Using NetApp StorageGRID tools, you can automate the installation and configuration of your StorageGRID appliances. After you install and configure the appliances, you can automate the configuration of the entire StorageGRID system.
You can automate the configuration of the following:
  • Grid Network, Admin Network, and Client Network IP addresses
  • BMC interface
  • Network links
    • Port bond mode
    • Network bond mode
    • Link speed
    • LACP transmit hash policy and PDU rate
Automation options
To automate appliance installation and configuration, use one or more of the following options:
  • Generate a JSON file that contains configuration details. Work with your NetApp Professional Services consultant to use the NetApp ConfigBuilder tool (login required) to complete these steps:
    1. Consult with NetApp Professional Services to get a sales order number.
    2. Get the workbook from ConfigBuilder.
    3. Consult with Professional Services to complete the workbook.
    4. Use ConfigBuilder to upload the workbook.
    5. Use ConfigBuilder to generate a JSON file.
    6. Consult with Professional Services to upload the JSON file to the appliance.
      Note You can use the same JSON file to configure more than one appliance.
    Configuring your appliance using an uploaded JSON file is often more efficient than performing the configuration manually, especially if you have to configure many nodes. Performing the configuration manually requires using multiple pages in the StorageGRID Appliance Installer and applying the configuration file for each node one at a time.
  • If you are an advanced user, you can use the following StorageGRID Python scripts to install and configure your system:
    Note You can use StorageGRID automation Python scripts directly, or you can use them as examples of how to use the StorageGRID Installation REST API in grid deployment and configuration tools you develop yourself. See the instructions for downloading and extracting the StorageGRID installation files.
Automate appliance configuration using StorageGRID Appliance Installer
After you have generated a JSON file, you can automate the configuration of one or more appliances by using the StorageGRID Appliance Installer to upload the JSON file.
Before you begin
  • The appliance has been installed in a rack, connected to your networks, and powered on.
  • You have generated the JSON file with the guidance of your NetApp Professional Services consultant.
  • Your appliance contains the latest firmware compatible with StorageGRID 11.5 or higher.
  • You are connected to the StorageGRID Appliance Installer on the appliance you are configuring using a supported web browser.
Steps
  1. In the StorageGRID Appliance Installer, select Advanced > Update Appliance Configuration. The Update Appliance Configuration page appears.
  2. In the Upload JSON section, browse for and select the JSON configuration file you want to upload.
    The file is uploaded and validated. When the validation process is complete, the file name is shown next to a green check mark.
    Note You might lose connection to the appliance if the configuration from the JSON file includes sections for link_config, networks, or both. If you aren't reconnected within 1 minute, re-enter the appliance URL using one of the other IP addresses assigned to the appliance.
    The Node name drop down is populated with the top-level node names defined in the JSON file.
    Note If the file is not valid, the file name is shown in red and an error message is displayed in a yellow banner. The invalid file is not applied to the appliance. ConfigBuilder verifies that you have a valid JSON file.
  3. Select a node from the list in the Node name drop down.
    The Apply JSON configuration button becomes enabled.
  4. Select Apply JSON configuration.
    The configuration is applied to the selected node.
Automate appliance installation and configuration using configure-sga.py script
If you are an advanced user, you can use the configure-sga.py script to automate many of the installation and configuration tasks for StorageGRID appliance nodes, including installing and configuring a primary Admin Node. This script can be useful if you have a large number of appliances to configure.
You can also use the script to generate a JSON file that contains appliance configuration information. You can upload the JSON file to the StorageGRID Appliance Installer to configure all appliance nodes at the same time. You can also edit the JSON file, then upload it to apply a new configuration to one or more appliances.
Note This procedure is for advanced users with experience using command-line interfaces. Alternatively, you can use the StorageGRID Appliance Installer to automate the configuration.
Before you begin
  • You have configured the IP address of the Admin Network for the appliance.
  • You have downloaded the configure-sga.py file. The file is included in the installation archive, or you can access it by clicking Help > Appliance Installation Script in the StorageGRID Appliance Installer.
Steps
  1. Log in to the Linux machine you are using to run the Python script.
  2. For general help with the script syntax and to see a list of the available parameters, enter the following:
    ./configure-sga.py --help
    The configure-sga.py script uses five subcommands:
    • advanced for advanced StorageGRID appliance interactions, including BMC configuration and creating a JSON file containing the current configuration of the appliance
    • configure for configuring the RAID mode, node name, and networking parameters
    • install for starting a StorageGRID installation
    • monitor for monitoring a StorageGRID installation
    • reboot for rebooting the appliance
      If you enter a subcommand (advanced, configure, install, monitor, or reboot) argument followed by the --help option you will get a different help text providing more detail on the options available within that subcommand:
      ./configure-sga.py subcommand --help
      If you will back up the appliance configuration to a JSON file, ensure the node names follow these requirements:
      • Each node name is unique if you want to automatically configure all appliance nodes using a JSON file.
      • Must be a valid hostname containing at least 1 and no more than 32 characters.
      • Can use letters, numbers, and hyphens.
      • Can't start or end with a hyphen.
      • Can't contain only numbers.
  3. To apply the configuration from the JSON file to the appliance, enter the following, where SGA-INSTALL-IP is the Admin Network IP address for the appliance, json-file-name is the name of the JSON file, and node-name-inside-json-file is the name of the node with the configuration being applied:
    ./configure-sga.py advanced --restore-file json-file-name --restore-node node-name-inside-json-file SGA-INSTALL-IP
  4. To confirm the current configuration of the appliance node, enter the following where SGA-INSTALL-IP is the Admin Network IP address for the appliance:
    ./configure-sga.py configure SGA-INSTALL-IP
    The results show current IP information for the appliance, including the IP address of the primary Admin Node and information about the Admin, Grid, and Client Networks.
    Connecting to +https://10.224.2.30:8443+ (Checking version and connectivity.)
    2021/02/25 16:25:11: Performing GET on /api/versions... Received 200
    2021/02/25 16:25:11: Performing GET on /api/v2/system-info... Received 200
    2021/02/25 16:25:11: Performing GET on /api/v2/admin-connection... Received 200
    2021/02/25 16:25:11: Performing GET on /api/v2/link-config... Received 200
    2021/02/25 16:25:11: Performing GET on /api/v2/networks... Received 200
    2021/02/25 16:25:11: Performing GET on /api/v2/system-config... Received 200
        Node type:   storage
      StorageGRID primary Admin Node
        IP:        172.16.1.170
        State:     unknown
        Message:   Initializing...
        Version:   Unknown
      Network Link Configuration
        Link Status
              Link      State      Speed (Gbps)
              1         Up         10
              2         Up         10
              3         Up         10
              4         Up         10
              5         Up         1
              6         Down       N/A
        Link Settings
            Port bond mode:      FIXED
            Link speed:          10GBE
            Grid Network:        ENABLED
                Bonding mode:    active-backup
                VLAN:            novlan
                MAC Addresses:   00:a0:98:59:8e:8a  00:a0:98:59:8e:82
            Admin Network:       ENABLED
                Bonding mode:    no-bond
                MAC Addresses:   00:80:e5:29:70:f4
            Client Network:      ENABLED
                VLAN:            novlan
                MAC Addresses:   00:a0:98:59:8e:89  00:a0:98:59:8e:81
      Grid Network
        CIDR:      172.16.2.30/21 (Static)
        MAC:       00:A0:98:59:8E:8A
        Gateway:   172.16.0.1
        Subnets:   172.17.0.0/21
                   172.18.0.0/21
                   192.168.0.0/21
        MTU:       1500
      Admin Network
        CIDR:      10.224.2.30/21 (Static)
        MAC:       00:80:E5:29:70:F4
        Gateway:   10.224.0.1
        Subnets:   10.0.0.0/8
                   172.19.0.0/16
                   172.21.0.0/16
        MTU:       1500
      Client Network
        CIDR:      47.47.2.30/21 (Static)
        MAC:       00:A0:98:59:8E:89
        Gateway:   47.47.0.1
        MTU:       2000
    #####   If you are satisfied with this configuration,    #####
    ##### execute the script with the "install" sub-command. #####
  5. If you need to change any of the values in the current configuration, use the configure subcommand to update them. For example, if you want to change the IP address that the appliance uses for connection to the primary Admin Node to 172.16.2.99, enter the following:
    ./configure-sga.py configure --admin-ip 172.16.2.99 SGA-INSTALL-IP
    Note
    Do not use subnets that contain the following IPv4 addresses for the Grid Network, Admin Network, or Client Network of any node:
    • 192.168.130.101
    • 192.168.131.101
    • 192.168.130.102
    • 192.168.131.102
    • 198.51.100.2
    • 198.51.100.4
    For example, do not use the following subnet ranges for the Grid Network, Admin Network, or Client Network of any node:
    • 192.168.130.0/24 because this subnet range contains the IP addresses 192.168.130.101 and 192.168.130.102
    • 192.168.131.0/24 because this subnet range contains the IP addresses 192.168.131.101 and 192.168.131.102
    • 198.51.100.0/24 because this subnet range contains the IP addresses 198.51.100.2 and 198.51.100.4
  6. If you want to back up the appliance configuration to a JSON file, use the advanced and backup-file subcommands. For example, if you want to back up the configuration of an appliance with IP address SGA-INSTALL-IP to a file named appliance-SG1000.json, enter the following:
    ./configure-sga.py advanced --backup-file appliance-SG1000.json SGA-INSTALL-IP
    The JSON file containing the configuration information is written to the path of the output file specified, in this case the relative path for the file appliance-SG1000.json.
    Caution Check that the top-level node name in the generated JSON file matches the appliance name. Don't make any changes to this file unless you are an experienced user and have a thorough understanding of StorageGRID APIs.
  7. When you are satisfied with the appliance configuration, use the install and monitor subcommands to install the appliance:
    ./configure-sga.py install --monitor SGA-INSTALL-IP
    ./configure-sga.py monitor --monitor-storagegrid-install SGA-INSTALL-IP
  8. If you want to reboot the appliance, enter the following:
    ./configure-sga.py reboot SGA-INSTALL-IP
