Obtain additional equipment and tools for StorageGRID appliances
Before installing a StorageGRID appliance, confirm you have all of the additional equipment and tools that you need.
All appliances
You need the following equipment to install and configure all appliances.
- Screwdrivers
Phillips No. 2 screwdriver
Medium flat-blade screwdriver
- ESD wrist strap
- Service laptop
SSH client, such as PuTTY
1-GbE (RJ-45) port
Some ports might not support 10/100 Ethernet speeds. |
- Optional tools
Power drill with Phillips head bit
Flashlight
Appliance-specific equipment and tools
You need the following additional equipment to install and configure the SG100 and SG1000 hardware.
- Optical cables and transceivers
Cables, 1 to 4 of either:
TwinAx/Copper
Fibre/Optical
Transceivers/adapters, 1 to 4 of each, based on link speed (mixed speeds aren't supported):
SG100:
10-GbE SFP+
25-GbE SFP28
SG1000:
10-GbE QSFP-to-SFP adapter (QSA) and SFP+
25-GbE QSFP-to-SFP adapter (QSA) and SFP28
40-GbE QSFP+
100-GbE QSFP28
- Ethernet cables
RJ-45 (Cat5/Cat5e/Cat6/Cat6a)
You need the following additional equipment to install and configure the SG110 and SG1100 hardware.
TwinAx/Copper
Fibre/Optical
SG110:
10-GbE SFP+
25-GbE SFP28
SG1100:
40-GbE QSFP+
100-GbE QSFP28
- Ethernet cables
You need the following additional equipment to install and configure the SG120 and SG1200 hardware.
TwinAx/Copper
Fibre/Optical
SG120:
10-GbE SFP+
25-GbE SFP28
SG1200:
40-GbE QSFP+
100-GbE QSFP28
200-GbE QSFP56 (200GbE NIC only)
- Ethernet cables
You need the following additional equipment to install and configure the SG5700 hardware.
- Optical cables and SFP transceivers
Optical cables for the 10/25-GbE ports you plan to use
Optional: SFP28 transceivers if you want to use 25-GbE link speed
- Ethernet cables
- Optional tools
Mechanized lift for SG5760
You need the following additional equipment to install and configure the SG5800 hardware.
- Cables and SFP transceivers
Cables for the 10/25-GbE ports you plan to use
Optional: SFP28 transceivers if you want to use 25-GbE link speed and have optical cables
Optional: SFP+ transceivers if you want to use 10-GbE link speed and have optical cables
- Ethernet cables
- Optional tools
Mechanized lift for SG5860
You need the following additional equipment to install and configure the SG6000 hardware.
TwinAx/Copper
Fibre/Optical
10-GbE SFP+
25-GbE SFP28
- Ethernet cables
RJ-45 (Cat5/Cat5e/Cat6)
- Optional tools
Mechanized lift for 60-drive shelves
You need the following additional equipment to install and configure the SG6100 hardware.
- Cables and transceivers
TwinAx/Copper
Fibre/Optical
Transceivers/adapters, 1 to 8 of each, based on link speed (mixed speeds aren't supported):
10-GbE SFP+
25-GbE SFP28
100-GbE QSFP28
- Ethernet cables
- Optional tools
TwinAx/Copper
Fibre/Optical
10-GbE SFP+
25-GbE SFP28
40-GbE QSFP+
100-GbE QSFP28
200-GbE QSFP56 (200 GbE NIC only)
- Ethernet cables
- Optional tools
