Configure SANtricity for SG6260, SG6160, SG6000, SG5700, and SG5800 StorageGRID appliances
You can use SANtricity System Manager to monitor the status of the storage controllers, storage disks, and other hardware components in the storage controller shelf. You can also configure a proxy for E-Series AutoSupport that enables you to send AutoSupport messages from the appliance without the use of the management port.
The following StorageGRID appliances can access SANtricity System Manager:
SG5712
SG5760
SG5812
SG5860
SGF6024
SG6060
SG6160
SG6260
You use SANtricity System Manager to monitor the following:
Performance data such as storage array level performance, I/O latency, CPU utilization, and throughput
Hardware component status
Support functions including viewing diagnostic data
You can use SANtricity System Manager to configure the following settings:
Email alerts, SNMP alerts, or syslog alerts for the components in the storage controller shelf
E-Series AutoSupport settings for the components in the storage controller shelf.
For additional details on E-Series AutoSupport, see the NetApp E-Series documentation.
Drive Security keys, which are needed to unlock secured drives
You must set up and have access to SANtricity System Manager if the Drive Security feature is enabled for your appliance. -
Administrator password for accessing SANtricity System Manager
Set up and access SANtricity System Manager
You might need to access SANtricity System Manager on the storage controller to monitor the hardware in the storage controller shelf or to configure E-Series AutoSupport.
You are using a supported web browser.
To access SANtricity System Manager through Grid Manager, you have installed StorageGRID, and you have the Storage appliance administrator permission or Root access permission.
To access SANtricity System Manager using the StorageGRID Appliance Installer, you have the SANtricity System Manager administrator username and password.
To access SANtricity System Manager directly using a web browser, you have the SANtricity System Manager administrator username and password.
You must have SANtricity firmware 8.70 or higher to access SANtricity System Manager using the Grid Manager or the StorageGRID Appliance Installer. You can check your firmware version by using the StorageGRID Appliance Installer and selecting Help > About. |
Accessing SANtricity System Manager from the Grid Manager or from the Appliance Installer is generally meant only for monitoring your hardware and configuring E-Series AutoSupport. Many features and operations within SANtricity System Manager such as upgrading firmware don't apply to monitoring your StorageGRID appliance. To avoid issues, always follow the hardware installation and maintenance instructions for your appliance. |
There are three ways to access SANtricity System Manager, depending upon what stage of the installation and configuration process you are in:
If the appliance has not yet been deployed as a node in your StorageGRID system, you should use the Advanced tab in the StorageGRID Appliance Installer.
Once the node is deployed, you can no longer use the StorageGRID Appliance Installer to access SANtricity System Manager. -
If the appliance has been deployed as a node in your StorageGRID system, use the SANtricity System Manager tab on the Nodes page in Grid Manager.
If you can't use the StorageGRID Appliance Installer or Grid Manager, you can access SANtricity System Manager directly using a web browser connected to the management port.
This procedure includes steps for your initial access to SANtricity System Manager. If you have already set up SANtricity System Manager, go to the configure hardware alerts step.
Using either the Grid Manager or the StorageGRID Appliance Installer enables you to access SANtricity System Manager without having to configure or connect the management port of the appliance. |
Do one of the following:
Use the StorageGRID Appliance Installer and select Advanced > SANtricity System Manager
Use the Grid Manager and select Nodes >
appliance Storage Node> SANtricity System Manager
If these options aren't available or the login page does not appear, use the IP addresses for the storage controllers. Access SANtricity System Manager by browsing to the storage controller IP. -
Set or enter the administrator password.
SANtricity System Manager uses a single administrator password that is shared among all users.
Select Cancel to close the wizard.
Don't complete the Set Up wizard for a StorageGRID appliance.
Select Help to access the online help for SANtricity System Manager.
Use the Settings > Alerts section of the online help to learn about alerts.
Follow the “How To” instructions to set up email alerts, SNMP alerts, or syslog alerts.
Manage AutoSupport for the components in the storage controller shelf.
Use the SUPPORT > Support Center section of the online help to learn about the AutoSupport feature.
Follow the “How To” instructions to manage AutoSupport.
For specific instructions on configuring a StorageGRID proxy for sending E-Series AutoSupport messages without using the management port, go to the instructions for configuring storage proxy settings.
If Drive Security is enabled for the appliance, create and manage the security key.
SG5700 and SG5800For the SG5700 and SG5800 storage appliances follow the high-level steps to implement drive security in SANtricity System Manager.
SG6060For the SG6060 storage appliance, drive security can be automatically enabled on the SSD drives only if key management was configured before installing the Storage Appliance.
Equip your storage array with secure-capable drives (FDE drives or FIPS drives).
For volumes that require FIPS support, use only FIPS drives.
Mixing FIPS and FDE drives in a volume group or pool results in all drives being treated as FDE drives.
An FDE drive cannot be added to or used as a spare in an all-FIPS volume group or pool.
For the E2800 controller shelf, create a security key (a string of characters that is shared by the controller and drives for read and write access).
You can create an internal key from the controller's persistent memory or use an external key provided by a key management server.
To use an external key provided by a key management server, you must first establish authentication with a key management server in SANtricity System Manager.
Start installation of the appliance.
After appliance installation is complete, confirm that drive security was enabled for the StorageGRID flash cache and enable drive security for all remaining disk pools or volume groups (See Enable security for a pool or volume group in SANtricity System Manager).
SG6160The SG6160 storage appliance can be equipped with FIPS-compliant drives in both the SG6100-CN compute controller and the E4000 controller shelf. Drive encryption is configured separately for the SG6100-CN drives and E4000 drives.
Enable Drive Encryption for SED SSDs installed in the SG6100-CN compute node.
Create a security key (a string of characters shared by the controller and drives for read/write access).
After install is complete, enable drive security in SANtricity System Manager for all disk pools or volume groups.
SG6260The SG6260 storage appliance can be equipped with FIPS-compliant drives in both the SG6200-CN compute controller and the E4000 controller shelf. Drive encryption is configured separately for the SG6200-CN drives and E4000 drives.
Enable Drive Encryption for SED SSDs installed in the SG6200-CN compute node.
Review hardware status in SANtricity System Manager
You can use SANtricity System Manager to monitor and manage the individual hardware components in the storage controller shelf and to review hardware diagnostic and environmental information, such as component temperatures, as well as issues related to the drives.
To access SANtricity System Manager through Grid Manager, you have the Storage appliance administrator permission or Root access permission.
You must have SANtricity firmware 8.70 or higher to access SANtricity System Manager using the Grid Manager or the StorageGRID Appliance Installer. |
Enter the administrator username and password if required.
Click Cancel to close the Set Up wizard and to display the SANtricity System Manager home page.
The SANtricity System Manager home page appears. In SANtricity System Manager, the controller shelf is referred to as a storage array.
Review the information displayed for appliance hardware and confirm that all hardware components have a status of Optimal.
Click the Hardware tab.
Click Show back of shelf.
From the back of the shelf, you can view both storage controllers, the battery in each storage controller, the two power canisters, the two fan canisters, and expansion shelves (if any). You can also view component temperatures.
To see the settings for each storage controller, select the controller, and select View settings from the context menu.
To see the settings for other components in the back of the shelf, select the component you want to view.
Click Show front of shelf, and select the component you want to view.
From the front of the shelf, you can view the drives and the drive drawers for the storage controller shelf or the expansion shelves (if any).
If the status of any component is Needs Attention, follow the steps in the Recovery Guru to resolve the issue or contact technical support.
Set IP addresses for storage controllers using StorageGRID Appliance Installer
Management port 1 on each storage controller connects the appliance to the management network for SANtricity System Manager. If you can't access SANtricity System Manager from the StorageGRID Appliance Installer, set a static IP address for each storage controller to ensure that you don't lose your management connection to the hardware and the controller firmware in the controller shelf.
You are using any management client that can connect to the StorageGRID Admin Network, or you have a service laptop.
The client or service laptop has a supported web browser.
DHCP-assigned addresses can change at any time. Assign static IP addresses to the controllers to ensure consistent accessibility.
Follow this procedure only if you don't have access to SANtricity System Manager from the StorageGRID Appliance Installer (Advanced > SANtricity System Manager) or Grid Manager (Nodes > SANtricity System Manager). |
From the client, enter the URL for the StorageGRID Appliance Installer:
https://Appliance_Controller_IP:8443For
Appliance_Controller_IP, use the IP address for the appliance on any StorageGRID network.The StorageGRID Appliance Installer Home page appears.
Select Configure Hardware > Storage Controller Network Configuration.
The Storage Controller Network Configuration page appears.
Depending on your network configuration, select Enabled for IPv4, IPv6, or both.
Make a note of the IPv4 address that is automatically displayed.
DHCP is the default method for assigning an IP address to the storage controller management port.
It might take a few minutes for the DHCP values to appear. -
Optionally, set a static IP address for the storage controller management port.
You should either assign a static IP for the management port or assign a permanent lease for the address on the DHCP server. -
Select Static.
Enter the IPv4 address, using CIDR notation.
Enter the default gateway.
Click Save.
It might take a few minutes for your changes to be applied.
When you connect to SANtricity System Manager, you will use the new static IP address as the URL:
https://Storage_Controller_IP
