Change the link configuration of an SG5800 controller
You can change the Ethernet link configuration of the SG5800 controller. You can change the port bond mode, the network bond mode, and the link speed.
In rare instances, placing a StorageGRID appliance into maintenance mode might make the appliance unavailable for remote access. |
Options for changing the Ethernet link configuration of the SG5800 controller include:
Changing Port bond mode from Fixed to Aggregate, or from Aggregate to Fixed
Changing Network bond mode from Active-Backup to LACP, or from LACP to Active-Backup
Changing the LACP transmit hash policy and LACP PDU rate values
Enabling or disabling VLAN tagging, or changing the value of a VLAN tag
Changing the link speed to or from Auto (recommended), 10-GbE, or 25-GbE.
Select Configure Networking > Link Configuration from the menu.
Make the desired changes to the link configuration.
For more information about the options, see Configure network links.
When you are satisfied with your selections, click Save.
You might lose your connection if you made changes to the network or link you are connected through. If you aren't reconnected within 1 minute, re-enter the URL for the StorageGRID Appliance Installer using one of the other IP addresses assigned to the appliance:
https://SG5800_Controller_IP:8443If you made changes to the VLAN settings, the subnet for the appliance might have changed. If you need to change the IP addresses for the appliance, follow the configure StorageGRID IP addresses instructions.
From the StorageGRID Appliance Installer, select Configure Networking > Ping Test.
Use the Ping Test tool to check connectivity to IP addresses on any networks that might have been affected by the link configuration changes you made in the Change link configuration step.
In addition to any other tests you choose to perform, confirm that you can ping the grid IP address of the primary Admin Node, and the grid IP address of at least one other Storage Node. If necessary, correct any link configuration issues.
Once you are satisfied that your link configuration changes are working, reboot the node. From the StorageGRID Appliance Installer, select Advanced > Reboot Controller, and then select Reboot into StorageGRID.
It can take up to 20 minutes for the appliance to reboot and rejoin the grid. To confirm that the reboot is complete and that the node has rejoined the grid:
In the Grid Manager, select Nodes.
Verify that the appliance node has a normal status (green check mark icon
to the left of the node name), which indicates that no alerts are active and the node is connected to the grid.
