Set up StorageGRID appliance hardware
After applying power to the appliance, you configure the network connections that will be used by StorageGRID.
Required hardware configurations
Network connections
You must configure and verify the required network connections for all appliances:
BMC interface
You must configure the baseboard management controller (BMC) interface if you are installing one of the following appliances:
SG100
SG110
SG120
SG1000
SG1100
SG1200
SGF6024
SGF6112
SGF6212
SG6060
SG6160
SG6260
You can use the BMC interface to configure SNMP and other low-level settings for your appliances. It also enables you to troubleshoot your hardware installation, determine your appliance's power state, and control the identify LED on your appliance.
To learn more about what features you can use with the BMC, refer to Use the BMC interface.
Optional hardware configurations
SANtricity System Manager
You can configure SANtricity System Manager if you have one of the following appliances:
SG5712
SG5760
SG5812
SG5860
SGF6024
SG6060
SG6160
SG6260
SANtricity System Manager software allows you to:
Monitor system performance data, hardware component status, and support functions for your appliance
Manage drive security keys, SNMP and syslofg alerts, and administrator passwords for accessing SANtricity System Manager
Configure access to E-Series AutoSupport
Enable node or drive encryption
You can enable node or drive encryption to protect the drives and disks in your appliance.
Change RAID mode
You can change the RAID mode of your storage appliance to accommodate your storage and recovery needs.
The following appliances support changing the RAID mode:
SG5760
SG5860
SGF6024
SG6060
SG6160
SG6260
Remap network ports
You can remap the network ports on your appliance to optimize your network connections.
