Configure StorageGRID appliance IP addresses
Use the StorageGRID Appliance Installer to configure IP addresses and routing for the services appliance or Storage Node on the Grid, Admin, and Client Networks.
If you are using ConfigBuilder to generate a JSON file, you can configure IP addresses automatically. See Automate appliance installation and configuration.
You must either assign a static IP address for the appliance on each connected Grid or Admin Network or assign a permanent lease for the address on the DHCP server. Static IP address or DHCP configuration is optional for a connected Client Network.
To enable or disable a link or change the link configuration, see the following instructions:
Do not use subnets that contain the following IPv4 addresses for the Grid Network, Admin Network, or Client Network of any node:
For example, do not use the following subnet ranges for the Grid Network, Admin Network, or Client Network of any node:
In the StorageGRID Appliance Installer, select Configure Networking > IP Configuration.
The IP Configuration page appears.
To configure the Grid Network, select either Static or DHCP in the Grid Network section of the page and then enter your network settings.
StaticIf you selected Static, follow these steps to configure the Grid Network:
Enter the static IPv4 address, using CIDR notation.
Enter the gateway.
If your network does not have a gateway, re-enter the same static IPv4 address.
If you want to use jumbo frames, change the MTU field to a value suitable for jumbo frames, such as 9000. Otherwise, keep the default value of 1500.
The MTU value of the network must match the value configured on the switch port the node is connected to. Otherwise, network performance issues or packet loss might occur. For the best network performance, all nodes should be configured with similar MTU values on their Grid Network interfaces. The Grid Network MTU mismatch alert is triggered if there is a significant difference in MTU settings for the Grid Network on individual nodes. The MTU values don't have to be the same for all network types. -
Click Save.
When you change the IP address, the gateway and list of subnets might also change.
If you lose your connection to the StorageGRID Appliance Installer, re-enter the URL using the new static IP address you just assigned. For example,
https://appliance_IP:8443 -
Confirm that the list of Grid Network subnets is correct.
If you have grid subnets, the Grid Network gateway is required. All grid subnets specified must be reachable through this gateway. These Grid Network subnets must also be defined in the Grid Network Subnet List on the primary Admin Node when you start StorageGRID installation.
If the Client Network is not enabled, the default route will use the Grid Network gateway. -
To add a subnet, click the insert icon
to the right of the last entry. -
To remove an unused subnet, click the delete icon
DHCPIf you selected DHCP, follow these steps to configure the Grid Network:
After you select the DHCP radio button, click Save.
The IPv4 Address, Gateway, and Subnets fields are automatically populated. If the DHCP server is set up to assign an MTU value, the MTU field is populated with that value, and the field becomes read-only.
Your web browser is automatically redirected to the new IP address for the StorageGRID Appliance Installer.
Click Save.
To configure the Admin Network, select either Static or DHCP in the Admin Network section of the page and then enter your network settings.
To configure the Admin Network, you enable the Admin Network on the Link Configuration page. StaticIf you selected Static, follow these steps to configure the Admin Network:
Enter the static IPv4 address, using CIDR notation, for Management Port 1 on the appliance.
See Cable appliance for the Management Port 1 location on your appliance.
Enter the gateway.
The MTU value of the network must match the value configured on the switch port the node is connected to. Otherwise, network performance issues or packet loss might occur. -
Click Save.
https://appliance:8443 -
Confirm that the list of Admin Network subnets is correct.
You must verify that all subnets can be reached using the gateway you provided.
The default route can't be made to use the Admin Network gateway. -
DHCPIf you selected DHCP, follow these steps to configure the Admin Network:
Click Save.
To configure the Client Network, select either Static, DHCP, or None in the Client Network section of the page and then enter your network settings.
To configure the Client Network, make sure that the Client Network is enabled on the Link Configuration page. StaticIf you selected Static, follow these steps to configure the Client Network:
Click Save.
Confirm that the IP address for the Client Network gateway is correct.
If the Client Network is enabled, the default route is displayed. The default route uses the Client Network gateway and can't be moved to another interface while the Client Network is enabled. -
Click Save.
DHCPIf you selected DHCP, follow these steps to configure the Client Network:
The IPv4 Address and Gateway fields are automatically populated. If the DHCP server is set up to assign an MTU value, the MTU field is populated with that value, and the field becomes read-only.
Confirm that the gateway is correct.
NoneSelect None to enable the Client Network without specifying an IP address. The Client Network only needs an IP address for direct access. Enabling the Client Network without an IP address lets you to configure the Client Network VLAN interfaces in StorageGRID.
