ONTAP SAN driver overview
Learn about configuring an ONTAP backend with ONTAP and Cloud Volumes ONTAP SAN drivers.
Important information about ONTAP SAN drivers
Astra Control provides seamless protection, disaster recovery, and mobility (moving volumes between Kubernetes clusters) for volumes created with the ontap-nas, ontap-nas-flexgroup, and ontap-san drivers. See Astra Control replication prerequisites for details.
You must use
ontap-nasfor production workloads that require data protection, disaster recovery, and mobility. -
Use
ontap-san-economywhen anticipated volume usage is expected to be much higher than what ONTAP supports. -
Use
ontap-nas-economyonly where anticipated volume usage is expected to be much higher than what ONTAP supports, and theontap-san-economydriver cannot be used. -
Do not use use
ontap-nas-economyif you anticipate the need for data protection, disaster recovery, or mobility.
User permissions
Astra Trident expects to be run as either an ONTAP or SVM administrator, typically using the admin cluster user or a vsadmin SVM user, or a user with a different name that has the same role. For Amazon FSx for NetApp ONTAP deployments, Astra Trident expects to be run as either an ONTAP or SVM administrator, using the cluster fsxadmin user or a vsadmin SVM user, or a user with a different name that has the same role. The fsxadmin user is a limited replacement for the cluster admin user.
If you use the limitAggregateUsage parameter, cluster admin permissions are required. When using Amazon FSx for NetApp ONTAP with Astra Trident, the limitAggregateUsage parameter will not work with the vsadmin and fsxadmin user accounts. The configuration operation will fail if you specify this parameter.
While it is possible to create a more restrictive role within ONTAP that a Trident driver can use, we don’t recommend it. Most new releases of Trident will call additional APIs that would have to be accounted for, making upgrades difficult and error-prone.
