Prerequisites for deployment
Contributors netapp-aruldeepa
You have to install and configure the necessary protocol prerequisites on your host before you can deploy Trident.
Verify the requirements
  • Verify that your deployment meets all of the requirements.
  • Verify that you have a supported version of Docker installed. If your Docker version is out of date, install or update it.
    docker --version
  • Verify that the protocol prerequisites are installed and configured on your host.
NFS tools
Install the NFS tools using the commands for your operating system.
RHEL 8+
sudo yum install -y nfs-utils
Ubuntu
sudo apt-get install -y nfs-common
Warning Reboot your worker nodes after installing the NFS tools to prevent failure when attaching volumes to containers.
iSCSI tools
Install the iSCSI tools using the commands for your operating system.
RHEL 8+
  1. Install the following system packages:
    sudo yum install -y lsscsi iscsi-initiator-utils sg3_utils device-mapper-multipath
  2. Check that iscsi-initiator-utils version is 6.2.0.874-2.el7 or later:
    rpm -q iscsi-initiator-utils
  3. Set scanning to manual:
    sudo sed -i 's/^\(node.session.scan\).*/\1 = manual/' /etc/iscsi/iscsid.conf
  4. Enable multipathing:
    sudo mpathconf --enable --with_multipathd y --find_multipaths n
    Note Ensure etc/multipath.conf contains find_multipaths no under defaults.
  5. Ensure that iscsid and multipathd are running:
    sudo systemctl enable --now iscsid multipathd
  6. Enable and start iscsi:
Ubuntu
    sudo apt-get install -y open-iscsi lsscsi sg3-utils multipath-tools scsitools
  2. Check that open-iscsi version is 2.0.874-5ubuntu2.10 or later (for bionic) or 2.0.874-7.1ubuntu6.1 or later (for focal):
    dpkg -l open-iscsi
    sudo tee /etc/multipath.conf <<-EOF
    defaults {
        user_friendly_names yes
        find_multipaths no
    EOF
    sudo systemctl enable --now multipath-tools.service
    sudo service multipath-tools restart
  5. Ensure that open-iscsi and multipath-tools are enabled and running:
    sudo systemctl status multipath-tools
    sudo systemctl enable --now open-iscsi.service
    sudo systemctl status open-iscsi
NVMe tools
Install the NVMe tools using the commands for your operating system.
Note
  • NVMe requires RHEL 9 or later.
  • If the kernel version of your Kubernetes node is too old or if the NVMe package is not available for your kernel version, you might have to update the kernel version of your node to one with the NVMe package.
RHEL 9
sudo yum install nvme-cli
sudo yum install linux-modules-extra-$(uname -r)
sudo modprobe nvme-tcp
Ubuntu
sudo apt install nvme-cli
sudo apt -y install linux-modules-extra-$(uname -r)
FC tools
Install the FC tools using the commands for your operating system.
  • When using worker nodes that run RHEL/Red Hat Enterprise Linux CoreOS (RHCOS) with FC PVs, specify the discard mountOption in the StorageClass to perform inline space reclamation. Refer to Red Hat documentation.
RHEL 8+
    sudo yum install -y lsscsi device-mapper-multipath
  2. Enable multipathing:
  3. Ensure that multipathd is running:
    sudo systemctl enable --now multipathd
Ubuntu
    sudo apt-get install -y lsscsi sg3-utils multipath-tools scsitools
    defaults {
        find_multipaths no
    EOF
  3. Ensure that multipath-tools is enabled and running:
