Prerequisites for deployment
You have to install and configure the necessary protocol prerequisites on your host before you can deploy Trident.
Verify the requirements
Verify that your deployment meets all of the requirements.
Verify that you have a supported version of Docker installed. If your Docker version is out of date, install or update it.
docker --version -
Verify that the protocol prerequisites are installed and configured on your host.
NFS tools
Install the NFS tools using the commands for your operating system.
sudo yum install -y nfs-utils
sudo apt-get install -y nfs-common
Reboot your worker nodes after installing the NFS tools to prevent failure when attaching volumes to containers. |
iSCSI tools
Install the iSCSI tools using the commands for your operating system.
Install the following system packages:
sudo yum install -y lsscsi iscsi-initiator-utils sg3_utils device-mapper-multipath -
Check that iscsi-initiator-utils version is 6.2.0.874-2.el7 or later:
rpm -q iscsi-initiator-utils -
Set scanning to manual:
sudo sed -i 's/^\(node.session.scan\).*/\1 = manual/' /etc/iscsi/iscsid.conf -
Enable multipathing:
sudo mpathconf --enable --with_multipathd y --find_multipaths nEnsure etc/multipath.confcontainsfind_multipaths nounderdefaults. -
Ensure that
iscsidandmultipathdare running:sudo systemctl enable --now iscsid multipathd -
Enable and start
iscsi:sudo systemctl enable --now iscsi
sudo apt-get install -y open-iscsi lsscsi sg3-utils multipath-tools scsitools -
Check that open-iscsi version is 2.0.874-5ubuntu2.10 or later (for bionic) or 2.0.874-7.1ubuntu6.1 or later (for focal):
dpkg -l open-iscsi -
sudo tee /etc/multipath.conf <<-EOF defaults { user_friendly_names yes find_multipaths no } EOF sudo systemctl enable --now multipath-tools.service sudo service multipath-tools restartEnsure etc/multipath.confcontainsfind_multipaths nounderdefaults. -
Ensure that
open-iscsiandmultipath-toolsare enabled and running:sudo systemctl status multipath-tools sudo systemctl enable --now open-iscsi.service sudo systemctl status open-iscsi
NVMe tools
Install the NVMe tools using the commands for your operating system.
sudo yum install nvme-cli
sudo yum install linux-modules-extra-$(uname -r)
sudo modprobe nvme-tcp
sudo apt install nvme-cli
sudo apt -y install linux-modules-extra-$(uname -r)
FC tools
Install the FC tools using the commands for your operating system.
When using worker nodes that run RHEL/Red Hat Enterprise Linux CoreOS (RHCOS) with FC PVs, specify the
discardmountOption in the StorageClass to perform inline space reclamation. Refer to Red Hat documentation.
sudo yum install -y lsscsi device-mapper-multipath -
Ensure that
multipathdis running:sudo systemctl enable --now multipathd
sudo apt-get install -y lsscsi sg3-utils multipath-tools scsitools -
Ensure that
multipath-toolsis enabled and running:sudo systemctl status multipath-tools
