• Installation and setup for Linux
    • Overview of OnCommand Workflow Automation
    • System requirements for installing OnCommand Workflow Automation
    • Prerequisites for installing Workflow Automation
    • Managing high availability
      • Set up Workflow Automation in VCS for high availability
    • Setting up OnCommand Workflow Automation
      • OnCommand Workflow Automation data sources
        • Configuring a database user on DataFabric Manager
      • Configuring OnCommand Workflow Automation
    • Upgrade from OnCommand Workflow Automation 3.1 or later
    • Upgrading third-party products
    • Backing up the OnCommand Workflow Automation database
      • Backing up the WFA database using the CLI
      • Backing up the WFA database using the REST APIs
    • Restoring the OnCommand Workflow Automation database
      • Restoring the WFA database using the CLI
      • Restoring the WFA database using REST APIs
    • Import OnCommand Workflow Automation content
    • Managing OnCommand Workflow Automation SSL certificate
    • Managing Perl and Perl modules
    • Troubleshooting installation and configuration issues
  • Installation and setup for Windows
      • Set up Workflow Automation in MSCS for high availability
        • Configure SNMP
    • Upgrade OnCommand Workflow Automation
      • Upgrade from OnCommand Workflow Automation 3.1 or later versions
      • Backing up the WFA database using REST APIs
  • Workflow
    • Understanding Workflow Automation designer
      • Working with the building blocks in OnCommand Workflow Automation
    • Managing workflows
      • Customize predefined workflows
      • Creating workflows
        • Create a workflow
      • Create WFA workflow packs
      • Integrating WFA workflow packs with the SCM repository
    • Creating building blocks for workflows
      • Create a command
    • Coding guidelines for WFA
      • General PowerShell and Perl conventions for WFA
      • Guidelines for WFA building blocks
  • Manage and configure
      • Configure SNMP
    • OnCommand Workflow Automation Designer features
    • Set up a data source
    • Where to find information about MVEL
    • Users Window
    • Active Directory Groups window
    • Data Sources window
    • Credentials window
    • Schedules window
    • Workflows window
      • New Workflow window
    • Finders window
    • Filters window
    • Commands window
    • Templates window
    • Dictionary window
    • Remote System Types window
    • Cache Queries window
    • Packs window
    • Categories window
