Adjust file system capacity in NetApp Workload Factory
Adjust the solid-state drive (SSD) storage capacity of an FSx for ONTAP file system to match the needs of workloads with varying active working sets in NetApp Workload Factory. Manually increase capacity when usage exceeds your threshold, or reduce it when you're not using the working sets to save money. Alternatively, enable automatic capacity management so Workload Factory adds incremental storage as needs change over time, removing the burden of manual monitoring.
Decreasing SSD storage capacity is only supported for second-generation file systems. |
Adjust file system capacity manually
With elastic file system capacity, you can dynamically adjust the capacity of your file systems to match the needs of your workloads.
Changing file system capacity impacts IOPS for your FSx for ONTAP file system.
When you automatically provision IOPS for a file system, IOPS increases or decreases by 3 IOPS with every 1 GiB increase or decrease in SSD capacity.
When you provision IOPS manually, you might need to increase your IOPS allocation to support the increased file system capacity.
For SSD storage capacity limits, refer to Quotas in AWS FSx for NetApp ONTAP documentation.
To adjust capacity for a file system, you must first disable automatic capacity management.
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Dashboard, select Adjust SSD capacity.
Select the file system you want to adjust capacity for and then select Continue.
In the Adjust SSD capacity dialog, enter a number for Provisioned capacity.
Select the unit for the provisioned capacity.
Select Apply.
Enable automatic capacity and inode management
Enable capacity and inode management to let NetApp Workload Factory automatically add incremental storage to an FSx for ONTAP file system and inodes (files) to a volume as capacity needs change over time. These features remove the need to monitor capacity and inodes manually.
Only one account can manage these features.
Enable automatic capacity management and capacity notifications
Enable automatic capacity management to automatically add incremental storage up to the maximum size limit for an FSx for ONTAP file system. Set up notifications to get alerts when the file system reaches a certain capacity threshold.
Workload Factory scans the FSx for ONTAP file system every 30 minutes to check if incremental storage needs to be added.
The maximum amount of SSD storage capacity for all FSx for ONTAP file systems is 524,288 GiB. To request a quota increase, refer to Quotas in AWS FSx for NetApp ONTAP documentation.
Consider the following before you begin:
You must grant credentials with the view, planning, and analysis permission policy in Workload Factory to complete this task.
To make sure volume inodes increase along with storage capacity, you must associate a link. Learn how to associate an existing link or to create and associate a new link. After the link associates, return to this operation.
You shouldn't enable this feature during data migration because AWS imposes a minimum six-hour cool down period between SSD capacity increases. This restriction might delay adjustments, so plan accordingly.
Select the menu
From the Storage menu, select FSx for ONTAP.
From FSx for ONTAP, select the file system to enable automatic capacity for.
In the Automatic capacity management card, select Manage.
Select the capacity management method. The options are incremental and adaptive modes.
Incremental: increases capacity by a fixed amount at thresholds.
Threshold: Set the threshold lower than the incremental increase to trigger a notification from the Workload Factory notification service. The default is 70%.
The threshold setting is available only if you enabled the Workload Factory notification service.
Incremental increase: Enter the maximum percentage increase for the FSx for ONTAP file system. The default is 80%.
This is the threshold at which Workload Factory triggers a job to increase the capacity. For example, if the file system reaches 80% of capacity, then Workload Factory increases capacity.
Adaptive: predicts and changes capacity based on historical data.
Look-back: Set the analysis period in hours to determine how much historical data to consider for capacity predictions. The default is 120 hours.
Plan ahead: Set the buffer time in hours to ensure capacity is increased before it's actually needed. The default is 48 hours.
Select Enable automatic capacity management and the credentials view, planning, and analysis permissions.
Alternatively, disable the feature. If you need to increase file system capacity, you must first disable automatic capacity management.
Select Enable capacity notifications to turn on notifications when capacity reaches the threshold you set and whenever Workload Factory performs an automatic capacity increase. The default is 70%.
The capacity notification setting is available only if you enabled the Workload Factory notification service and when automatic capacity management is enabled.
Select Apply.
A file system scan occurs every 30 minutes to determine whether it needs additional capacity.
Enable inode management for a file system
Enable automatic inode management to increase the number of inodes (files) per volume up to the allowable limit.
Workload Factory scans the FSx for ONTAP file system every 30 minutes to verify available volume inodes and to check if incremental inodes need to be added. The count increases based on automatic inode management thresholds.
Terraform users: Terraform has a limitation that requires that all operations are completed within Terraform. Inode management isn't supported in Terraform, but you can enable automatic inode management in the Workload Factory console. |
To manage volume inodes automatically, you must associate a link. Learn how to associate an existing link or to create and associate a new link. After the link associates, return to this operation.
Automatic inode management can be set up with a warning threshold that triggers a notification from the Workload Factory notification service. To use this feature, you must enable the Workload Factory notification service first.
Select the menu
From FSx for ONTAP, select the actions menu of the file system to enable automatic inodes management for.
Select Manage.
Under Information, select the pencil icon next to Automatic inodes management. The pencil icon appears next to the dropdown arrow when the mouse hovers over the Automatic inodes management row.
In the Automatic inodes management dialog, provide the following:
Credentials: Select credentials with Automate permissions from the dropdown menu.
Select the enable button to Enable automatic inodes management.
Alternatively, disable the feature. If you need to increase the number of inodes, you must first disable automatic inodes management.
Warning threshold: Set the warning threshold lower than the threshold increase to trigger a notification from the Workload Factory notification service. The default is 70%.
The warning threshold setting is available only if you enabled the Workload Factory notification service.
Threshold increase: Enter the maximum percentage increase for the number of inodes (files) per volume. The default is 80%.
Incremental increase: Enter the percentage to increase the number of inodes (files) incrementally. The default is 10%.
Select Apply.
A file system scan occurs every 30 minutes to determine if the volumes need additional inodes (files) per volume.
