Learn about information security for NetApp Workload Factory
Information security is a core part of NetApp Workload Factory design and operation. Information Security, Cloud Platform, and Storage teams can use these details to evaluate and onboard Workload Factory in a way that supports enterprise security requirements.
What Workload Factory is
Workload Factory is a SaaS life-cycle management platform designed to help you optimize and manage workloads (for example, storage, VMware migrations, EDA projects, and database environments) using Amazon FSx for NetApp ONTAP. Your workloads run in AWS.
Workload Factory uses AWS APIs for all FSx for ONTAP operations that are natively available through AWS, and ONTAP REST APIs for Workload Factory operations that are supported by the platform but not natively available through AWS APIs.
Core security principles used in this guide
- Confidentiality
Protect data from unauthorized access through identity controls, least privilege, encryption, and network boundaries.
- Integrity
Protect systems and configurations from unauthorized or unintended change using permission scoping, change control, and auditability.
- Availability
Ensure authorized users can access the service and workloads through resilient AWS designs and operational monitoring.
Types of information covered in this guide
The following sections provide information to help you evaluate and onboard Workload Factory in a way that supports enterprise security requirements.
Security model and responsibilities
Architecture and connectivity
Identity, credentials, and least privilege
Data governance, privacy, and lifecycle
Observability and monitoring
AI controls and VPC components
Get started quickly
Start with view, planning, and analysis (read-only) permissions and expand only as required.
Use AWS CloudTrail to validate
sts:AssumeRoleactivity for the integration role. -
Decide upfront whether you need ONTAP-native operations that require deploying a Lambda link or NetApp Console agent.
Decide upfront whether generative AI is permitted and whether residency constraints require single-region inference profiles.
