Create a custom dashboard in NetApp Workload Factory
Create custom dashboards by describing what you want to monitor in plain language. The AI guides you through the setup so your dashboards match your workloads and priorities.
Custom dashboards use an AI-guided dialog to understand what you want to visualize. You describe your monitoring needs in natural language, and the system asks clarifying questions to ensure the dashboard meets your requirements.
Once created, you can check when your dashboard metrics were last refreshed and request an on-demand update. Learn how to refresh dashboard data.
Remember that custom dashboards are read-only by design and cannot make changes to your storage or workload configurations.
If your account admin has turned off AI features, you'll see a message and won't be able to create dashboards. Contact your administrator or learn about AI administration. |
Create a dashboard
Log in using one of the console experiences.
Select the menu
and then select Workloads Overview > Custom dashboards.If this is your first dashboard, you'll see a blank screen with sample prompts to help you get started. You can select Copy prompt to copy a sample prompt into the AI dialog text box.
Select Create new dashboard.
In the AI dialog, describe what you want to monitor.
Describe it in plain language. The AI will ask a few questions to better understand your needs.
Select
Respond to the AI's clarifying questions.
The AI might ask you to choose from several options to better understand what you need. Answer each question and select Continue, or select Skip to move past optional questions.
After answering all questions, select Continue to create your dashboard.
Your dashboard is being created. This might take a moment.
Your custom dashboard is created and added to the dashboard catalog. By default, the dashboard is private and only visible to you. You can change the visibility to public if you want to share it with other users in your Workload Factory account. Learn how to change dashboard visibility.
You'll get a notification when your dashboard is ready. If it can't be created, you'll get a notification with a link to try again. Learn about configuring notifications.
After creation, you can:
Change dashboard visibility to share with your team
Check the Last Updated timestamp and select Refresh data to request updated metrics
Refresh dashboard data to see the latest information
Edit dashboards to change what they show, including metrics, charts, and time ranges
Delete dashboards you no longer need
