Astra Control Center
本产品推出了新版本。
执行钩示例
贡献者
使用以下示例了解如何构建执行挂钩。您可以将这些挂钩用作模板或测试脚本。
简单的成功示例
这是一个简单的钩子示例,它成功地将消息写入标准输出和标准错误。
#!/bin/sh
# success_sample.sh
# A simple noop success hook script for testing purposes.
# args: None
# Writes the given message to standard output
# $* - The message to write
msg() {
    echo "$*"
# Writes the given information message to standard output
info() {
    msg "INFO: $*"
# Writes the given error message to standard error
error() {
    msg "ERROR: $*" 1>&2
# main
# log something to stdout
info "running success_sample.sh"
# exit with 0 to indicate success
info "exit 0"
exit 0
简单成功示例( bash 版本)
这是一个简单的钩子示例,该钩子成功地将消息写入标准输出和标准错误,并写入 bash 。
#!/bin/bash
# success_sample.bash
# args: None
msg() {
    echo "$*"
info() {
    msg "INFO: $*"
error() {
# main
info "running success_sample.bash"
info "exit 0"
exit 0
简单成功示例( zsh 版本)
这是一个简单的钩子示例,该钩子成功地将消息写入标准输出和标准错误,并写入 Z shell 。
#!/bin/zsh
# success_sample.zsh
# args: None
msg() {
    echo "$*"
info() {
    msg "INFO: $*"
error() {
# main
info "running success_sample.zsh"
info "exit 0"
exit 0
成功使用参数示例
以下示例演示了如何在挂机中使用 args 。
#!/bin/sh
# success_sample_args.sh
# A simple success hook script with args for testing purposes.
# args: Up to two optional args that are echoed to stdout
msg() {
    echo "$*"
info() {
    msg "INFO: $*"
error() {
# main
info "running success_sample_args.sh"
# collect args
arg1=$1
arg2=$2
# output args and arg count to stdout
info "number of args: $#"
info "arg1 ${arg1}"
info "arg2 ${arg2}"
info "exit 0"
exit 0
快照前 / 快照后挂钩示例
以下示例演示了如何对快照前和快照后挂钩使用同一脚本。
#!/bin/sh
# success_sample_pre_post.sh
# A simple success hook script example with an arg for testing purposes
# to demonstrate how the same script can be used for both a prehook and posthook
# args: [pre|post]
# unique error codes for every error case
ebase=100
eusage=$((ebase+1))
ebadstage=$((ebase+2))
epre=$((ebase+3))
epost=$((ebase+4))
msg() {
    echo "$*"
info() {
    msg "INFO: $*"
error() {
# Would run prehook steps here
prehook() {
    info "Running noop prehook"
    return 0
# Would run posthook steps here
posthook() {
    info "Running noop posthook"
    return 0
# main
# check arg
stage=$1
if [ -z "${stage}" ]; then
    echo "Usage: $0 <pre|post>"
    exit ${eusage}
fi
if [ "${stage}" != "pre" ] && [ "${stage}" != "post" ]; then
    echo "Invalid arg: ${stage}"
    exit ${ebadstage}
fi
info "running success_sample_pre_post.sh"
if [ "${stage}" = "pre" ]; then
    prehook
    rc=$?
    if [ ${rc} -ne 0 ]; then
        error "Error during prehook"
    fi
fi
if [ "${stage}" = "post" ]; then
    posthook
    rc=$?
        error "Error during posthook"
    fi
fi
exit ${rc}
故障示例
以下示例演示了如何处理挂机故障。
#!/bin/sh
# failure_sample_arg_exit_code.sh
# A simple failure hook script for testing purposes.
# args: [the exit code to return]
msg() {
    echo "$*"
info() {
    msg "INFO: $*"
error() {
# main
info "running failure_sample_arg_exit_code.sh"
argexitcode=$1
# log to stderr
error "script failed, returning exit code ${argexitcode}"
# exit with specified exit code
exit ${argexitcode}
详细故障示例
以下示例演示了如何处理挂机故障,并提供更详细的日志记录。
#!/bin/sh
# failure_sample_verbose.sh
# A simple failure hook script with args for testing purposes.
# args: [The number of lines to output to stdout]
msg() {
    echo "$*"
info() {
    msg "INFO: $*"
error() {
# main
info "running failure_sample_verbose.sh"
# output arg value to stdout
linecount=$1
info "line count ${linecount}"
# write out a line to stdout based on line count arg
i=1
while [ "$i" -le ${linecount} ]; do
    info "This is line ${i} from failure_sample_verbose.sh"
    i=$(( i + 1 ))
done
error "exiting with error code 8"
exit 8
退出代码示例失败
以下示例显示了一个连接失败并显示退出代码。
#!/bin/sh
msg() {
    echo "$*"
info() {
    msg "INFO: $*"
error() {
# main
argexitcode=$1
# log to stderr
exit ${argexitcode}
失败后成功示例
以下示例显示了首次运行时发生故障的挂钩,但在第二次运行后仍会成功。
#!/bin/sh
# failure_then_success_sample.sh
# A hook script that fails on initial run but succeeds on second run for testing purposes.
# Helpful for testing retry logic for post hooks.
# args: None
msg() {
    echo "$*"
info() {
    msg "INFO: $*"
error() {
# main
info "running failure_success sample.sh"
if [ -e /tmp/hook-test.junk ] ; then
    info "File does exist.  Removing /tmp/hook-test.junk"
    rm /tmp/hook-test.junk
    info "Second run so returning exit code 0"
    exit 0
else
    info "File does not exist.  Creating /tmp/hook-test.junk"
    echo "test" > /tmp/hook-test.junk
    error "Failed first run, returning exit code 5"
    exit 5
fi
