BlueXP classification
Known limitations
Contributors amgrissino netapp-tonacki
Known limitations identify functions that are not supported by this release of the product, or that do not interoperate correctly with it. Review these limitations carefully.
BlueXP classification release temporarily removed options
The December 2023 (version 1.26.6) release temporarily removed the following options:
  • The option to activate audit log collection has been disabled.
  • During the Directories investigation, the option to calculate the number of personal identifiable information (PII) data by Directories is not available.
  • The option to integrate data using Azure Information Protection (AIP) labels has been disabled.
BlueXP classification scanning limitations
BlueXP classification scans only one share under a volume
If you have multiple file shares under a single volume, BlueXP classification scans the share with the highest hierarchy. For example, if you have shares like the following:
  • /A
  • /A/B
  • /C
  • /D/E
Then the data in /A will be scanned. The data in /C and /D will not be scanned.
Workaround
There is a workaround to make sure you are scanning data from all the shares in your volume. Follow these steps:
  1. In the working environment, add the volume to be scanned.
  2. After BlueXP classification has completed scanning the volume, go to the Data Investigation page and create a filter to see which share is being scanned:
    You'll filter the data by "Working Environment Name" and "Directory Type = Share" to see which share is being scanned.
  3. Get the complete list of shares that exist in the volume so you can see which shares are not being scanned.
  4. Add the remaining shares to a share group.
    You'll need to add all the shares individually, for example:
    /C
    /D
  5. Perform these steps for each volume in the working environment that has multiple shares.
