Access BlueXP ransomware protection
You use NetApp BlueXP to log in to the BlueXP ransomware protection service.
To log in to BlueXP, you can use your NetApp Support Site credentials or you can sign up for a NetApp cloud login using your email and a password. Learn more about logging in.
Open a web browser and go to the BlueXP console.
The NetApp BlueXP login page appears.
Log in to BlueXP.
From the BlueXP left navigation, select Protection > Ransomware protection.
If this is your first time logging in to this service, the landing page appears.
Otherwise, the BlueXP ransomware protection Dashboard appears.
Start using the service.
If you don't have a BlueXP Connector or it's not the one for this service, you might need to contact NetApp Support or follow messages to sign up.
If you are new to BlueXP and haven't used any Connector, when you select "Ransomware protection", a message appears about signing up. Go ahead and submit the form. NetApp will contact you about your evaluation request.
If you are a BlueXP user with an an existing Connector, when you select "Ransomware protection", a message appears about signing up.
If you haven't done so already, select the Discover workloads option.
Refer to Discover workloads.
