Copy snapshot volume
PDF of this doc site
- System Manager
Creating your file...
Your file is ready
You can perform a Copy Volume process on a snapshot volume or a snapshot consistency group snapshot volume.
About this task
You can copy a snapshot volume to the target volume as performed in a normal Copy Volume operation. However, snapshot volumes cannot remain online during the copy volume process.
Steps
Select Storage › Snapshots.
Select the Snapshot Volumes tab.
The Snapshot Volumes table appears and displays all the snapshot volumes associated with the storage array.
Select the snapshot volume that you want to copy, and then select Copy Volume.
The Copy Volume dialog box appears, prompting you to select a target.
Select the target volume to be used as the copy destination, and then click Finish.
