SANtricity 11.6
Edit key management server settings
If you configured external key management, you can view and edit the key management server settings at any time.
Before you begin
External key management must be configured.
Steps
  1. Select Settings  Systems.
  2. Under Security key management, select View/Edit Key Management Server Settings.
  3. Edit information in the following fields:
    • Key management server address — Enter the fully qualified domain name or the IP address (IPv4 or IPv6) of the server used for key management.
    • KMIP port number — Enter the port number used for the Key Management Interoperability Protocol (KMIP) communications.
  4. Click Save.
