SANtricity 11.6
Drive states
System Manager reports various states for drives.
Accessibility states
State Definition
Bypassed
The drive is physically present, but the controller cannot communicate with it on either port.
Incompatible
One of the following conditions exists:
  • The drive is not certified for use in the storage array.
  • The drive has a different sector size.
  • The drive has unusable configuration data from an older or newer firmware version.
Removed
The drive has been improperly removed from the storage array.
Present
The controller can communicate with the drive on both ports.
Unresponsive
The drive is not responding to commands.
Role states
State Definition
Assigned
The drive is a member of a pool or volume group.
In-use hot spare
The drive is currently being used as a replacement for a drive that has failed. Hot spares are used only in volume groups, not pools.
Standby hot spare
The drive is ready to be used as a replacement for a drive that has failed. Hot spares are used only in volume groups, not pools.
Unassigned
The drive is not a member of a pool or volume group.
Availability states
State Definition
Failed
The drive is not working. The data on the drive is not available.
Impending Failure
It has been detected that the drive could fail soon. The data on the drive is still available.
Offline
The drive is not available for storing data usually because it is part of a volume group that is being exported or it is undergoing a firmware upgrade.
Optimal
The drive is working normally.
