System requirements for installing OnCommand Workflow Automation
PDF of this doc site
- Installation and setup for Linux
- Installation and setup for Windows
Creating your file...
You must be aware of the OnCommand Workflow Automation (WFA) hardware and software requirements before installing WFA.
Hardware requirements for installing WFA
The following table lists the minimum hardware requirements and the recommended hardware specifications for the WFA server.
Component | Minimum requirements | Recommended specifications |
CPU |
2.27 GHz or faster, 2 core, 64-bit |
RAM |
4 GB |
8 GB |
Free disk space |
5 GB |
20 GB |
If you are installing WFA on a virtual machine (VM), you should reserve the required memory and CPU so that the VM has sufficient resources. The installer does not verify the CPU speed. |
Software requirements for installing WFA
The following table lists all the operating system versions compatible with the WFA server.
Operating System | Version |
Red Hat Enterprise Linux |
6.5, 7.0, 7.1 64-bit operating systems, 7.2, 7.3 and 7.4 |
CentOS |
7.1, 7.2, and 7.3 |
WFA should be installed on dedicated physical machines or VMs. You must not install any other application on the server that runs WFA. |
Other minimum required software
One of the following supported browsers:
Mozilla Firefox
Microsoft Internet Explorer
Google Chrome
The latest version of Adobe Flash Player for your browser
Perl v5.10.1
You can obtain information about the Perl modules that should be installed by using the
./WFA-version_number.bin -l
command.
For more details, see the Interoperability Matrix Tool.
Related information
