Restore (regular) the WFA database using REST APIs
PDF of this doc site
- Installation and setup for Linux
- Installation and setup for Windows
Creating your file...
You can do a regular restore of the OnCommand Workflow Automation (WFA) database by using REST APIs. In a regular restore, you can only restore the WFA database.
You must have created a
.zip
backup of the WFA database. -
You must have admin or architect credentials.
If you are restoring the database as a part of the migration procedure, you must do a full restore.
Enter the following URL in the REST client browser:
https://IP address of WFA server/rest/backups
In the Backup window, select the POST method.
In the Part drop-down list, select Multipart Body.
In the File field, enter the following information:
In the Content type drop-down list, select multi-part/form-data.
In the Charset drop-down list, select ISO-8859-1.
In the File namefield, enter the name of the backup file as
backupFile
Click Browse.
Select the location of the
.zip
backup file.
Navigate to the
/opt/netapp/wfa/bin
directory, and restart the WFA services: -
Verify that the restore operation is successful and WFA is accessible.
