Known issues with this release
Known issues identify problems that might prevent you from using this release of the product successfully.
The following known issues affect the current release:
Incorrect ClusterRoleBinding created by Astra Control Center CRD during installation
Backup or clone fails for apps using PVCs with decimal units in Astra Control Center
Astra Control Center UI slow to show changes to app resources such as persistent volume changes
During app restore from backup Trident creates a larger PV than the original PV
App clones fail when using Service Account level OCP Security Context Constraints (SCC)
S3 buckets in Astra Control Center do not report available capacity
Reusing buckets between instances of Astra Control Center causes failures
Selecting a bucket provider type with credentials for another type causes data protection failures
Backups and snapshots might not be retained during removal of an Astra Control Center instance
Can't determine ASUP tar bundle status in scaled environment
Uninstall of Astra Control Center fails to clean up Traefik CRDs
Apply the following patch to all Kubernetes clusters where the acc-operator version 21.08.65 has been deployed. It should also be applied if the acc-operator is re-deployed.
To resolve this issue:
Replace
ACC_NAMESPACE
in the script below with the namespace you used to deploy Astra Control Center. -
Run the script.
The patch removes the following two subjects from ClusterRoleBinding: "acc-operator-manager-rolebinding"
- apiGroup: rbac.authorization.k8s.io kind: Group name: system:serviceaccounts - apiGroup: "" kind: Group name: system:serviceaccounts
App with user-defined label goes into "removed" state
If you define an app with a non-existent k8s label, Astra Control Center will create, manage, and then immediately remove the app. To avoid this, add the k8s label to pods and resources after the app is managed by Astra Control Center.
Unable to stop running app backup
There is no way to stop a running backup. If you need to delete the backup, wait until it has completed and then use the instructions in Delete backups. To delete a failed backup, use the Astra API.
Volumes created with decimal units fail using the Astra Control Center backup or clone process. See the knowledgebase article for more information.
After a data protection operation (clone, backup, restore) and subsequent persistent volume resize, there is up to a twenty-minute delay before the new volume size is shown in the UI. This delay in the UI can also occur when any app resources are added or modified. In this case, a data protection operation is successful within minutes and you can use the management software for the storage backend to confirm the change in volume size.
If you resize a persistent volume after creating a backup and then restore from that backup, the persistent volume size matches the new size of the PV instead of using the size of the backup.
Clone performance impacted by large persistent volumes
Clones of very large and consumed persistent volumes might be intermittently slow, dependent on cluster access to the object store. If the clone is hung and no data has been copied for more than 30 minutes, Astra Control terminates the clone action.
App clones fail using a specific version of PostgreSQL
App clones within the same cluster consistently fail with the Bitnami PostgreSQL 11.5.0 chart. To clone successfully, use an earlier or later version of the chart.
An application clone might fail if the original security context constraints are configured at the service account level within the namespace on the OCP cluster. When the application clone fails, it appears in the Managed Applications area in Astra Control Center with status Removed
Before backing up or cloning apps managed by Astra Control Center, check bucket information in the ONTAP or StorageGRID management system.
If you try to reuse a bucket used by another or previous installation of Astra Control Center, backup and restore will fail. You must use a different bucket or completely clean out the previously used bucket. You can't share buckets between instances of Astra Control Center.
When you add a bucket, select the correct bucket provider type with credentials that are correct for that provider. For example, the UI accepts NetApp ONTAP S3 as the type with StorageGRID credentials; however, this will cause all future app backups and restores using this bucket to fail.
If you have an evaluation license, be sure you store your account ID to avoid data loss in the event of Astra Control Center failure if you are not sending ASUPs.
Extra backups are retained as part of scheduled backup
Sometimes one or more backups in Astra Control Center are retained beyond the number specified to be retained in the backup schedule. These extra backups should be deleted as part of a scheduled backup but are not deleted and are stuck in a pending
state. To resolve the issue, force delete the extra backups.
Clone operation can't use other buckets besides the default
During an app backup or app restore, you can optionally specify a bucket ID. An app clone operation, however, always uses the default bucket that has been defined. There is no option to change buckets for a clone. If you want control over which bucket is used, you can either change the bucket default or do a backup followed by a restore separately.
Managing a cluster with Astra Control Center fails when default kubeconfig file contains more than one context
You cannot use a kubeconfig with more than one cluster and context in it. See the knowledgebase article for more information.
During ASUP collection, the status of the bundle in the UI is reported as either collecting
or done
. Collection can take up to an hour for large environments. During ASUP download the network file transfer speed for the bundle might be insufficient, and the download might time out after 15 minutes without any indication in the UI. Download issues depend on the size of the ASUP, the scaled cluster size, and if collection time goes beyond the seven day limit.
Uninstall of Astra Control Center fails to clean up the monitoring-operator pod on the managed cluster
If you did not unmanage your clusters before you uninstalled Astra Control Center, you can manually delete the pods in the netapp-monitoring namespace and the namespace with the following commands:
Delete
acc-monitoring
agent:oc delete agents acc-monitoring -n netapp-monitoring
Result:
agent.monitoring.netapp.com "acc-monitoring" deleted
Delete the namespace:
oc delete ns netapp-monitoring
Result:
namespace "netapp-monitoring" deleted
Confirm resources removed:
oc get pods -n netapp-monitoring
Result:
No resources found in netapp-monitoring namespace.
Confirm monitoring agent removed:
oc get crd|grep agent
Sample result:
agents.monitoring.netapp.com 2021-07-21T06:08:13Z
Delete custom resource definition (CRD) information:
oc delete crds agents.monitoring.netapp.com
Result:
customresourcedefinition.apiextensions.k8s.io "agents.monitoring.netapp.com" deleted
You can manually delete the Traefik CRDs:
Confirm which CRDs were not deleted by the uninstall process:
kubectl get crds |grep -E 'traefik'
ingressroutes.traefik.containo.us 2021-06-23T23:29:11Z ingressroutetcps.traefik.containo.us 2021-06-23T23:29:11Z ingressrouteudps.traefik.containo.us 2021-06-23T23:29:12Z middlewares.traefik.containo.us 2021-06-23T23:29:12Z serverstransports.traefik.containo.us 2021-06-23T23:29:13Z tlsoptions.traefik.containo.us 2021-06-23T23:29:13Z tlsstores.traefik.containo.us 2021-06-23T23:29:14Z traefikservices.traefik.containo.us 2021-06-23T23:29:15Z
Delete the CRDs:
kubectl delete crd ingressroutes.traefik.containo.us ingressroutetcps.traefik.containo.us ingressrouteudps.traefik.containo.us middlewares.traefik.containo.us serverstransports.traefik.containo.us tlsoptions.traefik.containo.us tlsstores.traefik.containo.us traefikservices.traefik.containo.us
ASUP collection stuck in a generating or uploading state
If an ASUP pod is killed or restarted, an ASUP collection might become stuck in a generating or uploading state. Perform the following Astra Control REST API call to initiate manual collection again:
HTTP method | Path |
POST |
/accounts/{accountID}/core/v1/asups |
This API workaround works only if performed more than 10 minutes after ASUP is started. |
