Cloud Volumes ONTAP
What's new in Cloud Volumes ONTAP 9.9.0
Contributors netapp-bcammett netapp-driley netapp-rlithman
Cloud Volumes ONTAP 9.9.0 includes several new features and enhancements.
Additional features and enhancements are also introduced in the latest versions of BlueXP. See the BlueXP Release Notes for details.
Latest update (21 Apr 2021)
In AWS, you can now configure up to 24 storage VMs (SVMs) for disaster recovery (DR). The previous limit was 12 storage VMs used for DR.
Latest updates (12 Apr 2021)
A few updates have been made since Cloud Volumes ONTAP 9.9.0 was released.
AWS updates
  • Cloud Volumes ONTAP now supports General Purpose SSD (gp3) disks, starting with the 9.7 release. gp3 disks are the lowest-cost SSDs that balance cost and performance for a broad range of workloads.
  • Cloud Volumes ONTAP no longer supports Cold HDD (sc1) disks.
These EBS disk changes were introduced as part of BlueXP 3.9.5.
Azure updates
  • New E series VM types are supported:
    • E4s_v3 with single node systems using PAYGO Explore or BYOL
    • E8s_v3 with single node systems using PAYGO Standard or BYOL, and HA pairs using PAYGO Premium or BYOL
    • E64is_v3 with single node systems using PAYGO Premium or BYOL
  • Up to 24 storage VMs (SVMs) are supported with Cloud Volumes ONTAP BYOL. Those 24 storage VMs can serve data or be configured for disaster recovery (DR).
    The previous limit in the 9.9.0 release was 12 storage VMs used for DR in Azure.
9.9.0 GA (9 Mar 2021)
The 9.9.0 GA release is available in AWS, Azure, and Google Cloud Platform. The release includes the following new features and enhancements.
Improved write performance
This release includes improved write performance for Cloud Volumes ONTAP in all cloud providers and on all configurations.
Support for new EC2 instance types
Cloud Volumes ONTAP is now supported with the following Amazon EC2 instance types:
  • m5a.2xlarge with Standard and BYOL
  • m5a.16xlarge with Premium and BYOL
  • c5a.12xlarge with Premium and BYOL
Learn more about M5a instances and C5a instances.
Support for 24 storage VMs in Azure
24 storage VMs are now supported with Cloud Volumes ONTAP in Azure when you bring your own license (BYOL). This includes up to 12 storage VMs used for DR.
An add-on license is required for each additional data-serving storage VM beyond the first storage VM that comes with Cloud Volumes ONTAP by default. Contact your account team to obtain an SVM add-on license.
Storage VMs that you configure for disaster recovery (DR) don't require an add-on license (they are free of charge), but they do count against the storage VM limit.
Required version of the BlueXP Connector
The BlueXP Connector must be running version 3.9.4 or later to deploy new Cloud Volumes ONTAP 9.9.0 systems and to upgrade existing systems to 9.9.0.
Changes introduced with version 3.9.4 of the Connector
The 3.9.4 release of the Connector includes a few enhancements for the management of Cloud Volumes ONTAP, including enhancements to AWS KMS support, shared VPC support in Google Cloud, and reduced IPs in Google Cloud.
Go to the BlueXP Release Notes for more details about the 3.9.4 release.
Upgrade notes
  • Upgrades of Cloud Volumes ONTAP must be completed from BlueXP. You should not upgrade Cloud Volumes ONTAP by using System Manager or the CLI. Doing so can impact system stability.
  • You can upgrade to Cloud Volumes ONTAP 9.9.0 from the 9.8 release. BlueXP will prompt you to upgrade your existing Cloud Volumes ONTAP 9.8 systems to the 9.9.0 release.
  • The upgrade of a single node system takes the system offline for up to 25 minutes, during which I/O is interrupted.
  • Upgrading an HA pair is nondisruptive and I/O is uninterrupted. During this nondisruptive upgrade process, each node is upgraded in tandem to continue serving I/O to clients.
  • In AWS, the c4, m4, and r4 EC2 instance types are no longer supported with new Cloud Volumes ONTAP deployments. If you have an existing system that's running on a c4, m4, or r4 instance type, you must change to an instance type in the c5, m5, or r5 instance family. If you can't change the instance type, you need to enable enhanced networking before upgrading.
    Refer to NetApp Support to learn more about the end of availability and support for these instance types.
