Quick start for NetApp Data Migrator
Getting started with NetApp Data Migrator includes a few steps.
Learn about NetApp Data MigratorNetApp Data Migrator supports NFS and SMB file transfer protocols. Determine that NetApp Data Migrator supports your data migration needs and choose the deployment option that suits your environment:
AWS
Azure
Google Cloud services
Open Virtual Appliance (OVA) templates
Install and set upNetApp Data Migrator uses a control plane and worker nodes. First you deploy the control plane VM and worker VMs based on your migration needs. For NFS, you deploy a Linux worker and for SMB, you deploy a Windows worker. You can use NFS or SMB, or both protocols. After deployment, you create the control plane VM and worker VMs and access the NetApp Data Migrator UI.
Learn how to:
Configure and manageYou first log in as an administrator using the default credentials and update your username and password. Then you can create your first project and add the file servers to initiate migration workflows.
Learn how to:
