Maintain the hardware - EF300 and EF600
You might need to perform maintenance procedures on your hardware. Procedures specific to maintaining your EF300, EF600, EF300C, or EF600C system components are in this section.
The procedures in this section assume that the EF300 or EF600 system has already been deployed in the E-Series environment.
System components
For the EF300, EF600, EF300C, and EF600C storage systems, you can perform maintenance procedures on the following components.
A battery is included with a controller and preserves cached data if the AC power fails.  |
A controller consists of a board, firmware, and software. It controls the drives and implements the SANtricity System Manager functions.  |
You must replace a DIMM (dual in-line memory module) when a memory mismatch is present, or you have a failed DIMM.  |
A drive is a device that provides the physical storage media for data.  |
Each EF300 or EF600 controller shelf or drive shelf includes five fans for cooling the controller.  |
A host interface card (HIC) must be installed within a controller canister. The EF600 controller includes host ports on the optional HIC. Host ports that are built into the HIC are called HIC ports.  |
You can convert the protocol of a host to a different protocol so that compatibility and communication can be established.  |
A power supply provides a redundant power source in a controller shelf.  |
A SAS expansion card may be installed within a controller canister. The EF300 controller supports SAS expansion.  |
