Element Software
Configure SolidFire system options after deployment
Contributors netapp-pcarriga
After you set up your SolidFire system, you might want to perform some optional tasks.
If you change credentials in the system, you might want to know the impact on other components.
Additionally, you can configure settings for multi-factor authentication, external key management, and Federal Information Processing Standards (FIPS) security. You should also look at updating passwords when needed.
