Keystone
2.0
View and manage alerts for Keystone subscriptions
Contributors netapp-shwetav
The Keystone dashboard in the NetApp Console allows you to view and manage active alerts in your Keystone storage environment. You can see both system-generated alerts and user-defined alerts for capacity usage and subscription expiration. From this view, you can quickly assess alert severity, identify storage issues, and take corrective actions. This view is not available in Digital Advisor.
To configure user-defined alerts, refer to Create and manage alert monitors.
View alerts
To view active alerts, follow these steps:
Steps
  1. From the Console left navigation menu, select Storage > Keystone > Monitoring > Alerts.
    A screenshot of active alerts for Keystone subscriptions
    You can view alert details such as severity, ID, type and condition, description, triggered time, subscription number, tracking ID, performance service level, and status. The page also shows the total unresolved alerts by severity and type.
    Note The Reports tab is currently unavailable for Keystone subscriptions.
    Tip You can customize the table using the column selector column selector icon icon.
Manage alerts
From the Alerts tab, you can perform the following actions:
  • Review and resolve alerts: Select the alert ID to open a detailed view of the alert. This view displays the alert description and suggested resolution steps. From this detailed view, you can mark the alert as resolved using the Edit button or add supporting notes using the Add note button.
    You can also use the ellipsis icon next to the Status column to perform the following actions:
    • Edit: Opens a pop-up to change the alert status and add resolution details.
    • Add note: Opens a pop-up to add a note to the alert.
    • View: Opens the same detailed view as selecting the alert ID.
      Note Editing alerts requires the Keystone admin role. The Keystone viewer role can only view alert details. To learn more, refer to Keystone access roles in NetApp Console.
  • Filter alerts: Use the filter icon in the Status column to view only active alerts, resolved alerts, or both.
  • View subscription details: Select the subscription number from the Subscription column to access subscription details, consumption trends, and asset information that can help you understand and address the alert. For more information, refer to View your current consumption details.
Related information
