Delete a CIFS server and related configurations
Deletes a CIFS server and its associated configurations when you need to remove CIFS services from your environment.
HTTP method and endpoint
DELETE /protocols/cifs/services/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
Deletes a CIFS server and related CIFS configurations.
Related ONTAP commands
vserver cifs server delete -
vserver cifs remove-netbios-aliases
Learn more
return_timeout |
integer |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
ad_domain |
Example request
"ad_domain": {
"fqdn": "example.com",
"organizational_unit": "string",
"password": "string",
"user": "string"
Status: 202, Accepted
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
ad_domain
fqdn |
string |
The fully qualified domain name of the Windows Active Directory to which this CIFS server belongs. A CIFS server appears as a member of Windows server object in the Active Directory store. POST and PATCH only. |
organizational_unit |
string |
Specifies the organizational unit within the Active Directory domain to associate with the CIFS server. POST and PATCH only. |
password |
string |
The account password used to add this CIFS server to the Active Directory. This is not audited. |
user |
string |
The user account used to add this CIFS server to the Active Directory. |
cifs_service_delete
ad_domain |
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
