REST API reference
Delete a CIFS server and related configurations
Deletes a CIFS server along with its related configurations. Use this endpoint when you need to remove CIFS settings from your system, such as during decommissioning or configuration updates.
HTTP method and endpoint
DELETE /protocols/cifs/services/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
Deletes a CIFS server and related CIFS configurations.
If "force" field is set along with user login credentials, the local CIFS configuration will be deleted irrespective of any communication errors. The default value for this field is false. If "force" field alone is set without passing the user login credentials, the local CIFS configuration will be deleted by not making any request to Active Directory, but the option will be enable only for the VseverDR enabled SVMs. The default value for this field is false.
  • vserver cifs server delete
  • vserver cifs remove-netbios-aliases
force
boolean
query
False
When set, the local CIFS configuration is deleted irrespective of any communication errors. Default value for this field is false.
  • Introduced in: 9.11
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
svm.uuid
string
path
True
Request Body
Name Type Description
ad_domain
ad_domain
Example request
  "ad_domain": {
    "fqdn": "example.com",
    "organizational_unit": "string",
    "password": "string",
    "user": "string"
Status: 202, Accepted
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
ad_domain
fqdn
string
The fully qualified domain name of the Windows Active Directory to which this CIFS server belongs. A CIFS server appears as a member of Windows server object in the Active Directory store. POST and PATCH only.
organizational_unit
string
Specifies the organizational unit within the Active Directory domain to associate with the CIFS server. POST and PATCH only.
password
string
The account password used to add this CIFS server to the Active Directory. This is not audited.
user
string
The user account used to add this CIFS server to the Active Directory.
cifs_service_delete
ad_domain
ad_domain
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
