Delete a CIFS server and related configurations
Deletes a CIFS server and its associated configurations. Use this operation to remove a server when it is no longer needed or to reset configurations.
HTTP method and endpoint
DELETE /protocols/cifs/services/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
Deletes a CIFS server and related CIFS configurations.
Important notes:
The default value for the "force" field is false.
If the "force" field is set along with user login credentials, the local CIFS configuration will be deleted irrespective of any communication errors.
If the "force" field alone is set without passing the user login credentials, the local CIFS configuration will be deleted by not making any request to Active Directory.
Related ONTAP commands
vserver cifs server delete -
vserver cifs remove-netbios-aliases
Learn more
force |
boolean |
query |
False |
When set, the local CIFS configuration is deleted irrespective of any communication errors. Default value for this field is false.
return_timeout |
integer |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
ad_domain |
auth_user_type |
string |
Specifies the type of user who can access the SMB Volume. The default is domain_user. In the case of a hybrid-user, ONTAP won't contact on-premise ADDS.
authentication_method |
string |
Specifies the authentication method. The available values are:
client_certificate |
string |
PKCS12 certificate used by the application to prove its identity to AKV. |
client_id |
string |
Application client ID of the deployed Azure application with appropriate access to an AKV or EntraId. |
client_secret |
string |
Secret used by the application to prove its identity to AKV. |
key_vault_uri |
string |
URI of the deployed AKV that is used by ONTAP for storing keys.
oauth_host |
string |
Open authorization server host name. |
proxy_host |
string |
Proxy host. |
proxy_password |
string |
Proxy password. Password is not audited. |
proxy_port |
integer |
Proxy port. |
proxy_type |
string |
Proxy type. |
proxy_username |
string |
Proxy username. |
tenant_id |
string |
Directory (tenant) ID of the deployed Azure application with appropriate access to an AKV or EntraId. |
timeout |
integer |
AKV connection timeout, in seconds. The allowed range is between 0 to 30 seconds. |
verify_host |
boolean |
Verify the identity of the AKV host name. By default, verify_host is set to true. |
workgroup |
string |
The workgroup name. |
Example request
"ad_domain": {
"fqdn": "example.com",
"organizational_unit": "string",
"password": "string",
"user": "string"
"auth_user_type": "string",
"authentication_method": "string",
"client_certificate": "PEM Cert",
"client_id": "e959d1b5-5a63-4284-9268-851e30e3eceb",
"client_secret": "<id_value>",
"key_vault_uri": "https://kmip-akv-keyvault.vault.azure.net/",
"oauth_host": "login.microsoftonline.com",
"proxy_host": "proxy.eng.com",
"proxy_password": "proxypassword",
"proxy_port": 1234,
"proxy_type": "string",
"proxy_username": "proxyuser",
"tenant_id": "c9f32fcb-4ab7-40fe-af1b-1850d46cfbbe",
"timeout": 25,
"workgroup": "workgrp1"
Status: 200, Ok
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655525 |
In order to delete an Active Directory machine account for the CIFS server, you must supply the name and password of a Windows account with sufficient privileges. |
3735751 |
Failed to authenticate and retrieve the access token from the Azure OAuth host. |
3735752 |
Failed to extract the private key from the Azure Key Vault certificate. |
3735753 |
Unsupported content_type in the Azure secrets response. |
3735754 |
Failed to parse the JSON response from Azure Key Vault. |
3735755 |
REST API call to Azure failed. |
3735756 |
Invalid client certificate. |
3735757 |
Failed to generate client assertion. |
3735762 |
The provided Azure Key Vault configuration is incorrect. |
3735763 |
The provided Azure Key Vault configuration is incomplete. |
3735764 |
Request to Azure failed. Reason - Azure error code and Azure error message. |
655563 |
NetBIOS name contains characters that are not allowed. |
655562 |
NetBIOS name is longer than 15 characters. |
655923 |
Retrieving credentials from AKV is not supported because the effective cluster version is not ONTAP 9.15.0 or later. |
656487 |
Missing fields when doing CIFS operation with hybrid auth user type. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
ad_domain_delete
fqdn |
string |
The fully qualified domain name of the Windows Active Directory to which this CIFS server belongs. A CIFS server appears as a member of Windows server object in the Active Directory store. POST and PATCH only. |
organizational_unit |
string |
Specifies the organizational unit within the Active Directory domain to associate with the CIFS server. POST and PATCH only. |
password |
string |
The account password used to add this CIFS server to the Active Directory. This is not audited. |
user |
string |
The user account used to add this CIFS server to the Active Directory. |
cifs_service_delete
ad_domain |
auth_user_type |
string |
string |
string |
client_id |
string |
client_secret |
string |
key_vault_uri |
string |
oauth_host |
string |
proxy_host |
string |
Proxy host. |
proxy_password |
string |
proxy_port |
integer |
Proxy port. |
proxy_type |
string |
Proxy type. |
proxy_username |
string |
Proxy username. |
tenant_id |
string |
timeout |
integer |
verify_host |
boolean |
workgroup |
string |
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
