Delete CIFS server and related configurations
Deletes a CIFS server and its associated configurations. Use this operation when you need to remove CIFS services and clean up related settings.
HTTP method and endpoint
DELETE /protocols/cifs/services/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
Deletes a CIFS server and related CIFS configurations.
Important notes:
The default value for the "force" field is false.
If the "force" field is set along with user login credentials, the local CIFS configuration will be deleted irrespective of any communication errors.
If the "force" field alone is set without passing the user login credentials, the local CIFS configuration will be deleted by not making any request to Active Directory.
Related ONTAP commands
vserver cifs server delete -
vserver cifs remove-netbios-aliases
Learn more
force |
boolean |
query |
False |
When set, the local CIFS configuration is deleted irrespective of any communication errors. Default value for this field is false.
return_timeout |
integer |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
ad_domain |
Example request
"ad_domain": {
"fqdn": "example.com",
"organizational_unit": "string",
"password": "string",
"user": "string"
Status: 202, Accepted
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
ad_domain
fqdn |
string |
The fully qualified domain name of the Windows Active Directory to which this CIFS server belongs. A CIFS server appears as a member of Windows server object in the Active Directory store. POST and PATCH only. |
organizational_unit |
string |
Specifies the organizational unit within the Active Directory domain to associate with the CIFS server. POST and PATCH only. |
password |
string |
The account password used to add this CIFS server to the Active Directory. This is not audited. |
user |
string |
The user account used to add this CIFS server to the Active Directory. |
cifs_service_delete
ad_domain |
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
