REST API reference
Delete a CIFS server and related configurations
Deletes a CIFS server along with its related configurations. Use this operation to remove CIFS settings when they are no longer needed, ensuring any specific options like "force" are appropriately set to handle communication scenarios.
HTTP method and endpoint
DELETE /protocols/cifs/services/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
Deletes a CIFS server and related CIFS configurations.
Important notes:
  • The default value for the "force" field is false.
  • If the "force" field is set along with user login credentials, the local CIFS configuration will be deleted irrespective of any communication errors.
  • If the "force" field alone is set without passing the user login credentials, the local CIFS configuration will be deleted by not making any request to Active Directory.
  • vserver cifs server delete
  • vserver cifs remove-netbios-aliases
force
boolean
query
False
When set, the local CIFS configuration is deleted irrespective of any communication errors. Default value for this field is false.
  • Introduced in: 9.11
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
svm.uuid
string
path
True
Request Body
Name Type Description
ad_domain
ad_domain_delete
auth_user_type
string
Specifies the type of user who can access the SMB Volume. The default is domain_user. In the case of a hybrid-user, ONTAP won't contact on-premise ADDS.
  • enum: ["domain_user", "hybrid_user"]
  • Introduced in: 9.16
  • x-nullable: true
authentication_method
string
Specifies the authentication method. The available values are:
  • client_secret
  • certificate
client_certificate
string
PKCS12 certificate used by the application to prove its identity to AKV.
client_id
string
Application client ID of the deployed Azure application with appropriate access to an AKV or EntraId.
client_secret
string
Secret used by the application to prove its identity to AKV.
key_vault_uri
string
URI of the deployed AKV that is used by ONTAP for storing keys.
oauth_host
string
Open authorization server host name.
proxy_host
string
Proxy host.
proxy_password
string
Proxy password. Password is not audited.
proxy_port
integer
Proxy port.
proxy_type
string
Proxy type.
proxy_username
string
Proxy username.
tenant_id
string
Directory (tenant) ID of the deployed Azure application with appropriate access to an AKV or EntraId.
timeout
integer
AKV connection timeout, in seconds. The allowed range is between 0 to 30 seconds.
verify_host
boolean
Verify the identity of the AKV host name. By default, verify_host is set to true.
workgroup
string
The workgroup name.
Example request
  "ad_domain": {
    "fqdn": "example.com",
    "organizational_unit": "string",
    "password": "string",
    "user": "string"
  "auth_user_type": "string",
  "authentication_method": "string",
  "client_certificate": "PEM Cert",
  "client_id": "e959d1b5-5a63-4284-9268-851e30e3eceb",
  "client_secret": "<APPLICATION-CLIENT-SECRET-FOR-AKV>",
  "key_vault_uri": "https://kmip-akv-keyvault.vault.azure.net/",
  "oauth_host": "login.microsoftonline.com",
  "proxy_host": "proxy.eng.com",
  "proxy_password": "proxypassword",
  "proxy_port": 1234,
  "proxy_type": "string",
  "proxy_username": "proxyuser",
  "tenant_id": "c9f32fcb-4ab7-40fe-af1b-1850d46cfbbe",
  "timeout": 25,
  "workgroup": "workgrp1"
Status: 200, Ok
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
655525
In order to delete an Active Directory machine account for the CIFS server, you must supply the name and password of a Windows account with sufficient privileges.
3735751
Failed to authenticate and retrieve the access token from the Azure OAuth host.
3735752
Failed to extract the private key from the Azure Key Vault certificate.
3735753
Unsupported content_type in the Azure secrets response.
3735754
Failed to parse the JSON response from Azure Key Vault.
3735755
REST API call to Azure failed.
3735756
Invalid client certificate.
3735757
Failed to generate client assertion.
3735762
The provided Azure Key Vault configuration is incorrect.
3735763
The provided Azure Key Vault configuration is incomplete.
3735764
Request to Azure failed. Reason - Azure error code and Azure error message.
655563
NetBIOS name contains characters that are not allowed.
655562
NetBIOS name is longer than 15 characters.
655923
Retrieving credentials from AKV is not supported because the effective cluster version is not ONTAP 9.15.0 or later.
656487
Missing fields when doing CIFS operation with hybrid auth user type.
656505
The LDAP parameters bind_as_cifs_server or restrict_discovery_to_site are enabled for this SVM which requires CIFS server to be present. Deletion of CIFS server will affect LDAP functionality. If you still want to delete the CIFS server retry the operation with force parameter set to true.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
ad_domain_delete
fqdn
string
The fully qualified domain name of the Windows Active Directory to which this CIFS server belongs. A CIFS server appears as a member of Windows server object in the Active Directory store. POST and PATCH only.
organizational_unit
string
Specifies the organizational unit within the Active Directory domain to associate with the CIFS server. POST and PATCH only.
password
string
The account password used to add this CIFS server to the Active Directory. This is not audited.
user
string
The user account used to add this CIFS server to the Active Directory.
cifs_service_delete
ad_domain
ad_domain_delete
auth_user_type
string
  • x-nullable: true
string
  • client_secret
  • certificate
client_certificate
string
client_id
string
client_secret
string
key_vault_uri
string
oauth_host
string
proxy_host
string
Proxy host.
proxy_password
string
proxy_port
integer
Proxy port.
proxy_type
string
Proxy type.
proxy_username
string
Proxy username.
tenant_id
string
timeout
integer
verify_host
boolean
workgroup
string
The workgroup name.
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
